Introduction: Make the Esp8266 Chip a Little Bit Easier to Program!
For starters the esp8266 12-e can be hard to figure out that's why I made this instrucatable, to make it easier to figure out!
Step 1: Why Is the Esp8266 a Little Tricky?
Well the pins on the board are different then the GPIO pins. Look at the pictures that describe how the pins are different.
Step 2: Install the Esp Chip on Arduino Ide
Fallowing the images:
1) go into the preferences and go into additional boards manager add this url ("http://arduino.esp8266.com/stable/package_esp8266com_index.json ") then save that
2) Install the ESP boards in the boards manager
Easy!
Step 3: Use an Array for Your Pins
A super easy way to convert your board pins to the gpio pins is to use this array.
int pin[]{16, 5, 4, 0, 2, 14, 12, 13, 15};
So now to use the pins how they are used on the board just use "pin[whateverpinislistedontheboard]"
Step 4: Need It More Simple?
The codes above will blink the on board LED's (the ESP8266 12-E has two), the led on the wifi chip is connected to D0 and the led on the main board is connected to D4. Use the fallowing code o flash the led's back and
fourth
void setup() {
pinMode(pin[0], OUTPUT); //this would actually be GPIO 16
pinMode(pin[4], OUTPUT); //this would actually be GPIO 0
void loop() {
digitalWrite(pin[0], HIGH);
digitalWrite(pin[4], LOW);
delay(500);
digitalWrite(pin[0], LOW);
digitalWrite(pin[4], HIGH);
delay(500);
About This Instructable
1,895views
34favorites
License:
Bio: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths ... More »
More by Funguypro:3D Print Your House!!!!!DIY Raspberry Pi Indoor Outdoor WebcamSee Through Buildings With a Drone
Add instructable to:
