Introduction: Make the Volume Knob of Sound Blaster X-Fi Surround 5.1 Pro Sound Card Work in Raspberry Pi
Picture of Make the Volume Knob of Sound Blaster X-Fi Surround 5.1 Pro Sound Card Work in Raspberry Pi
Introduction
After completing "Create a Volume Control for USB Sound Card in Raspberry Pi" instructable, the volume of the sound card is controllable by a "software" volume controller. However, the sound card's built-in hard volume knob (the shiny circular object as shown in the picture) was still unusable. I felt it was a shame to leave it at that. So after digging around, I learned that the sound card has an infrared receiver interface. However, this particular sound card that I purchased did not come with remote control in the box. The surprising thing is that the built-in volume knob communicates with the sound card's infrared receiver and Linux Infrared Remote Control (LIRC) could read the signals received by the sound card's infrared receiver. This was a pleasant surprise!
Scope
This instructable will cover the following:
  • Create software volume control
  • Install LIRC
  • Train LIRC to capture signals received by the hard volume knob of the sound card
  • Configure LIRC's Daemon to monitor ALSA device's Infrared Receiver
  • Configure LIRC's IREXEC to map LIRC keys and control ALSA software volume control
  • Use ALSA utilities to test sound card and sound device
This instructables will NOT cover the following
  • PulseAudio
  • Open Sound System (OSS)
Specifications
My Raspberry Pi:
  • Raspberry Pi 2 model
  • Raspbian based on Debian Version 8.0 (a.k.a Jessie)
  • Advanced Linux Sound Architecture Driver Version k4.1.10-v7+
  • Pulse Audio and OSS are NOT installed. You must UNINSTALL PulseAudio or any other sound servers.
  • 2 speakers connected to Raspberry Pi's audio/video 3.5mm socket.
Step 1: Install Sound Blaster X-Fi Surround 5.1 Pro Sound Card
Complete the steps in "Use USB Sound Card in Raspberry Pi" instructable.
Step 2: Change the Name and Index of the Sound Card in Raspberry Pi
Step 3: Test Sound Card and Speakers
Step 4: Create a Software Volume Control
The Sound Blaster X-Fi Surround 5.1 Pro sound card does NOT provide any hardware mixer. Therefore a software volume control is needed.
Complete the steps in "Create a Volume Control for USB Sound Card in Raspberry Pi" instructable.
Step 5: Install LIRC Software
Step 6: Train LIRC to Capture Signals From X-Fi Surround 5.1 Pro Sound Card Infrared Receiver
Picture of Train LIRC to Capture Signals From X-Fi Surround 5.1 Pro Sound Card Infrared Receiver
Open terminal emulator of Raspberry Pi.
Stop the LIRC daemon
$sudo service lirc stop
$cd ~
Run the program irrecord
$irrecord --device=hw:0,0 --driver=alsa_usb my_lirc_control.conf
Refer to screenshot. The irrecord's wizard is launched.
Follow all the wizard's instructions.
When wizard says: "Hold down an arbitrary button"
We continuously turn the volume knob clockwise.
When the wizard says "Please enter the name for the next button (press to finish recording)"
We type KEY_VOLUMEUP
When the wizard says: Now hold down button "KEY_VOLUMEUP".
We continuously turn the volume know clockwise until the wizard tell us to do something else.<br>
When the wizard says: Please enter the name for the next button (press to finish recording)
We type KEY_VOLUMEDOWN
When the wizard says: Now hold down button "KEY_VOLUMEDOWN"
We continuously turn the volume know ANTI-clockwise until the wizard tell us to do something else.
When the wizard says: "Please enter the name for the next button (press to finish recording)"
We press "ENTER" key to tell wizard that we want to stop recording.
When the wizard says: "Please press an arbitrary button repeatedly as fast as possible.
Make sure you keep pressing the SAME button and that you DON'T HOLD the button down!."
We turn the volume knob clockwise until a dot appears. Stop for 3 second and repeat until:<br>
The wizard will display "Successfully written config file" at the end".
If you make any mistake along the way, you can press Control + C to abort. Delete the my_lirc_control.conf file. Then run irrecord again.
Check the configuration file ~/my_lirc_control.conf as shown in the third screenshot.
ls -l ~/my_lirc_control.conf
Step 7: Configure LIRC Daemon to Monitor X-Fi Sound Card's ALSA Device
Picture of Configure LIRC Daemon to Monitor X-Fi Sound Card's ALSA Device
Open the terminal emulator
cd /etc/lirc
Make backup before we modify the file
sudo cp hardware.conf hardware.conf.pristine
sudo cp lircd.conf lircd.conf.pristine
Refer to screenshot. Change the settings in the hardware.conf which is a configuration file
sudo vi hardware.conf
Save the hardware.conf file.
Place the LIRC configuration file in /etc/lirc directory
sudo cp ~/my_lirc_control.conf /etc/lirc/lircd.conf
Change the name of the remote in the /etc/lirc/lircd.conf to something more descriptive like "sb_xfi_surround_51_pro_volume_knob"
sudo vi /etc/lirc/lircd.conf
Step 8: Check Whether the LIRC Daemon Is Ready to Use LIRC Interface
Picture of Check Whether the LIRC Daemon Is Ready to Use LIRC Interface
Open terminal emulator:
sudo service lirc start
sudo service lirc status
"..........lircd(alsa_usb) ready, using /var/run/lirc/lircd" means LIRC daemon is ready to send LIRC events to the LIRC interface. If you do NOT see this message, then you cannot proceed to the next step because no application can receive any LIRC events.
Step 9: Test Whether LIRC Daemon Is Responding Correctly to X-Fi Sound Card's Volume Knob Events
Picture of Test Whether LIRC Daemon Is Responding Correctly to X-Fi Sound Card's Volume Knob Events
Open terminal:
irw
Turn hard volume knob clockwise.<strong><br>Expected Result:</strong><br>irw should display one or more of the following message:<strong><br>0000000000000010 00 KEY_VOLUMEUP my_lirc_control.conf</strong>
Turn hard volume knob ANTI-clockwise.<strong><br>Expected Result:</strong><br>irw should display one or more of the following message:<strong><br>000000000000000f 00 KEY_VOLUMEDOWN my_lirc_control.conf</strong>
Refer to screenshot
Step 10: Configure IREXEC Software
Picture of Configure IREXEC Software
IREXEC is a program launcher. It responds to LIRC daemon's button/key events.
Open terminal
cd /etc/lirc
Create a system-wide configuration
sudo vi lircrc
Refer to screenshot. Enter lines as shown.
Save the file
Step 11: Test IREXEC Configuration
Picture of Test IREXEC Configuration
ircat irexec
Turn the volume knob clockwise.
Expected result is "amixer sset Master 1+" messages are shown
Turn the volume knob ANTI-clockwise.
Expected result is "amixer sset Master 1-" messages are shown
Step 12: Test the System
Picture of Test the System
Open terminal:
alsamixer
Turn the volume knob clockwise. The Master Volume should add coloured bars as you turn the volume knob.
Turn the volume knob ANTI-lockwise. The Master Volume should remove coloured bars as you turn the volume knob.
Open another terminal:
speaker-test -c2 -twav
The speakers volume should vary when you turned the volume knob clockwise or ANTI-clockwise.
About This Instructable
6,311views
17favorites
Bio: Systems Administrator and Software Programmer.
More by mirza irwan osman:Install Modem USB Device in Raspberry PiMake the Volume Knob of Sound Blaster X-Fi Surround 5.1 Pro Sound Card Work in Raspberry PiCreate a Volume Control for USB Sound Card in Raspberry Pi
Add instructable to:
