Regardless, I think we all hold a place near and dear to our hearts for the cube. It is a timeless symbol of geekiness! Let us not forget it!
In this instructable, I will teach you how to pay tribute to this awesome cube. It's simple to do and anyone can achieve the awesomeness that is the final project. Wow your friends and read on!
Remove these ads by
Signing UpStep 1Bake the cake
You will need:
-Recipe or cake mix of your choosing X2
-9x9 square inch cake pans. (You can either have three or you can bake the cake in shifts)
-Nonstick spray
-Your choice of frosting
-Your choice of filling
-LOTS of food coloring in red, green, yellow, and blue. -This will be for the squares
-Either black food coloring or dark chocolate ganache.- Depends on your taste. This will cover the cube. Black food coloring tends to dye mouths purple and a ganache can be shinier. However, you might achieve more of a black by using food coloring. More on this later.
-Fondant- I highly recommend making your own marshmallow fondant. It's simply, delicious, and looks very professional
So, get started baking your cake. You will want to prepare double your recipe for this cake. I like to use box mixes because they are no fuss and turn out delicious. I do, however, think it makes a world of a difference to prepare your own frosting. Poor your batter into designated square pans. If you have to rotate one pan to bake all three, it won't hurt, but it will take longer. ;) Bake until the cakes lightly bounce back when you touch them or just before.
FYI- Cakes actually continue baking in their pans even when you pull them out of the oven. To get a really moist cake, pull the cake out just before it looks done and it should cook to perfection. In my opinion, nothing beats a moist cake. Another thing I suggest to maintain moistness is to put some cling wrap over the cake when it cools a bit. It will collect the condensation and keep your cake very moist! I usually only do this for cakes that have a tendency to dry out more such as chocolate, but do what you like!
Everyone loved it!!!!
Check out the cake and the details of my party here:
http://elizabethdoodah.blogspot.com/2011/08/happy-30th-jeff-rubix-cube-cake-ecto.html
I just used my pound cake recipe but it does not rise enough so I need to start again.
Also where it says double the mix is that for each cake or just double and make 3 cakes out of it?
Thanks
Fondant: 1st batch had too much oil.. 2nd time was practically perfect. Coloring & kneading the fondant to the right color was VERY time consuming & hard for me. I also rushed on the tiles because I was running out of time..
Cake & Icing: I used an 8x8 cake pan and cut it into 4s, therefore the center was very moist and practically impossible to put icing on. That is why I end up with such an irregular shaped cake. The instructions on the black dye said to mix it with chocolate frosting, and I ended up with a matte black colored frosting.
Thank you very much for posting this, it is really a great idea because my boyfriend loves the rubik's cube and he liked the cake, so mission accomplished. :D
Im going to make this in celebration of 111009... the perfect g33k party. All I need is a case of Bawls rootbeer. http://www.thinkgeek.com/caffeine/drinks/2818/
-PKT
