3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make the world's brightest blue led flashlight
Make the world\
How to change your 3 watt(or 1 or possibly even 4 watt) rayovac led flashlight's beam color?
Want to spend $30 on a badass led flashlight and convert it into a badder ass BLUE led flashlight?
WANT TO VOID YOUR WARRENTY?!
dont read on, please dont, we dont want you to click step 2!!!
go here instead, neither site will void your warrenty www.google.com or maybe www.alluc.org
ok, if you are still here, click step 2 and have fun
http://www.google.com/products?q=3+watt+rayovac+flashlight
buy the flashlight here, i got it at menards
Step 1Open it up!
Open it up!
out of the box, the flashlight has the lens and reflector glued on, do not worry if it is hard to unscrew, you will NOT break it
grab the flashlight and twist counterclockwise
do the same with the led module(by the way, if your flashlight ever starts to get dim and flicker, clean the aluminum where the led module connects to the flashlight, aluminum against aluminum oxidizes badly and the connection grows poor)
18 comments
Aug 11, 2010. 9:50 AMtraitor561 says:
dude that light is so bright i want 1 but cant make it
May 19, 2009. 4:15 PMlolzertank says:
Nice idea, especially with scraping the phosphor off the rebel. Blue light is just cool. I wouldn't try this with anything but a TFFC rebel or K2. With anything else you'll probably rip off the tiny bond wires with the scraping and dome removal.
Mar 14, 2009. 7:01 PMrimar2000 says:
What is the advantage of a blue flashlight over a white? (Forgive my ignorance ...)
Mar 14, 2009. 8:59 PMLftndbt says:
Conventionally a red LeD is used in dark environments, to not disintegrate you natural night vision. An incandescent or white light causes your retinas to close making it hard to see, in the darkness around you. I would imagine blue would work in a similar fashion. Not sure if that is the purpose of this particular I'ble. It may be of advantage because it is just nice looking and unique though.
Mar 16, 2009. 2:16 PMstone3408 says:
A blue LED is at the 430-460 nm range. Night vision is based on IR that is in the 900 nm range. Red is about 560 nm. The advantage is that the blue is less detectable by night vision. Check this light out and the research http://www.phantomlights.com/faq.phtml
Mar 18, 2009. 10:21 AMstone3408 says:
Have you even looked at the link that I posted?
Mar 18, 2009. 12:15 PMrimar2000 says:
Yes, very interesting.
Mar 18, 2009. 10:20 AMstone3408 says:
If that is true I would like to see a photograph of the research that you have done to prove your point. All of the research that I have done with my gen 1-3 tubes have shown a significant reduction in dispersed light. It is true that all night vision works across the spectrum, however, it is designed to be more sensitive toward the IR end. To tell a person their understanding is " very off " is quite rude. So lets see what you have now: pics, research, or just uninformed rudeness.
Mar 16, 2009. 7:02 PMLftndbt says:
Thanks for the clarification. Although I do doubt that being "less detectable by night vision" was the main purpose of this particular convertion. Not exactly alot of people using night vision to track you in the burbs.
Mar 16, 2009. 4:46 PMrimar2000 says:
Thanks to both.
Mar 14, 2009. 8:24 AMMakerBreaker says:
i have that same royovac flashlight
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Frogz
