Make you own wearable arc reactor and be cooler than Tony Stark!
After seeing the new movie Iron Man did you want a cool arc reactor of your very own? Well I can show you how to make one!( sorry but it wont create energy to keep shrapnel from your heart)
Great for an awesome effect on Halloween or any day you want to be cool!
If you like it, PLEASE VOTE!!
Step 1So you wanna be cooler than Tony Stark?...
Well heres a few notes before we get started.
1. this project requires soldering
2.this project is only my representation of this and i encourage you to make yours special. Feel free to comment to help improve it!
3. This project, like many things in my life, was made on a whim. I am positive there are better ways to do some of these steps so please feel free to improve on them and share.
4 Have fun with it, i intend to wear mine with a tee shirt to school as well as add it to my Iron man suit (a real one made of steel and aluminum which includes a frame, armor, weapons etc. No, I'm serious, Instructable coming soon.)
5. SERIOUSLY DO NOT WEAR THIS IN AN AIRPORT OR ANY SUCH PLACE WHERE YOU WILL LOOK SUSPICIOUS
If you enjoy this Instructable, i would really appreciate if you would vote and comment!
Thanks,
mspark400
191 comments
1-40 of 191next »
Jul 19, 2011. 6:17 PMgrundisimo says:
If you plan on doing this, try using metallic spray paint. Easier and cleaner looking.
Jun 13, 2009. 10:36 PMreactor011 says:
i am also making an iron man suit of armor. I am only 13. I don't have rockets but i do have the laser tech and I also can make it hover like 10 feet in the air (I SWEAR TO U) I also have the machine gun on it. The machine gun was broken down so it could become part of the suit. It is still in production. I can tell you some componenets to make it fly so u can fly around too. I also put a computer chip in the back of it so I could control it from my laptop when i'm not in it.
Jul 19, 2011. 6:09 PMgrundisimo says:
The laser tech he uses is illegal, not to mention that it isn't small enough to fit.
May 31, 2010. 6:45 PMspaceboy22 says:
could you teach me how to make an iron man arc reactor?
Jun 10, 2010. 4:57 PMTr1t1um1 says:
i could and im jack im 14
Jul 27, 2009. 8:40 AMI3uckwheat says:
pictures or it didnt hapen
Jul 21, 2009. 7:06 AMTFElite says:
You know how much thrust that would actually take to get you even off the ground? Unless you had something equivalent to a mini jet booster, its not going to happen.
Jul 21, 2009. 1:18 PMTFElite says:
And plus, there is no way to beak down a machine gun to fit inside the suit. It just won't work to fit in with all of the other components you'd need to power the suit. Also, adding a computer chip in the back to control it when you're not in it? Three problems with that: 1. You couldn't use a laptop. It'd need the most powerful processing system built. 2: You can't control a whole suit from just a computer chip. You'd need a whole motherboard. And 3: I forgot to mention that there wouldn't be enough room for the gun anyways because of the size of the stabilizers that would be there.
Jul 22, 2009. 11:16 AMreactor011 says:
I didn't break a machine gun down I just simply mounted it in the back. and secondly the suit wasn't that advanced and the only thing I have the computer chip is to release the locks onto the suit keeping it together and I downloaded the data on a disk to take it wherever I want it to go. and the reason I can't fly where ever I want to I can only fly 10 feet exactly because of the jet fuel I load into my suit(I load into the back in to big cases) so apparently my suit is the size of a bulk buster
Jul 22, 2009. 11:34 AMreactor011 says:
And I power it by making an arc reactor that can plug into the wall it uses power then gives power
May 9, 2010. 1:12 PMmakerboy112 says:
Your retarted. There is NO way you could hover. You would need an incredible amount of thrust. Beisdes, where in the hell can you get jet fuel when your 13?
Jun 10, 2010. 6:32 PMTr1t1um1 says:
buy kerosene
Jun 10, 2010. 4:25 PMTr1t1um1 says:
you don't use jet fuel you use ion thrusters that can produce 8800 pounds of thrust by using the atom xenon and electrostaticly accelerating it through a grid
Jun 10, 2010. 5:27 PMmakerboy112 says:
Are those even real?
Jun 10, 2010. 6:31 PMTr1t1um1 says:
yes they charg atoms and thy use thm to creat a force to help thm move
Jun 11, 2010. 8:59 AMmakerboy112 says:
But the kid said thathe used jet fuel
Jun 12, 2010. 3:12 AMTr1t1um1 says:
even if he had a jet engine it still wouldnt lift before it explodes
Jul 19, 2011. 6:05 PMgrundisimo says:
And the amount of fuel required for that would be too heavy for the suit to lift off. Not to mention that you would need a fifty pound car battery to power it.
Jun 10, 2010. 4:59 PMTr1t1um1 says:
doesnt use to much voltage either
Jul 23, 2009. 7:45 AMTFElite says:
Then why did you say: "The machine gun was broken down so it could become part of the suit" and also "also put a computer chip in the back of it so I could control it from my laptop when i'm not in it"? By the way, jet fuel is not legally sold to minor like that because of its high flammability. And if your suit is the size of a bulk buster combined with the weight of the suit and combined with the typical 13 year old weight, its going to take almost a full jet booster to get off the ground. And to load the "Data" on a disk, you would need a disk with TERABYTES of data, which aren't currently produced. And to give it enough power to actually turn it ON from a power outlet? That would take weeks to charge. AND its illegal for minors to own a machine gun.
Jul 23, 2009. 12:52 PMreactor011 says:
The reason I said it was broken down because I took down the part that you hold and moved it to another area on the gun to have it sit on my shoulder and btw all your doing is trying to show someone up but right now your failing
Jul 24, 2009. 6:43 PMTFElite says:
Actually, your concepts are the ones that are failing.
1. You can't actually lift yourself up with this kind of technology, it just won't work.
2. Also, with this technology, you wouldn't be able to "hover" with no stabilizers. No stabilizers=no stability. No stability=uncontrollable flying. And you should know what that leads to.
3. You can't just take the handle of a gun and move it to another place. There's more machinery in the handle. You move that, you have to move EVERYTHING.
4. The ark reactor technology doesn't exist yet. If it was, it would be on the news everywhere.
Jun 10, 2010. 4:44 PMTr1t1um1 says:
(removed by author or community request)
Jun 10, 2010. 6:34 PMTr1t1um1 says:
i now more about how an arc reactor works
Jul 25, 2009. 10:14 AMreactor011 says:
I am not going to fued with you All ANYONE NEEDS TO KNOW is I made it I going to have pictures of it up monday and maybe a vid and yes I had help. And plus how are you going to go and bag on me because I'm 13. And the thrust was lifted up by the gas in my mom's truck and also my cousin has one of those huge trucks that hold allot of gas for me to hover 10 feet and if it went uncontrolable the tube would pop off and immediatly stop the flying instntly. So please stop trying to start a fued and please stop finding FLAWS THAT I HAVE TO FIX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 10, 2010. 4:51 PMTr1t1um1 says:
by the way im 14
Jun 10, 2010. 4:49 PMTr1t1um1 says:
maybe i could give you different plans that could maybe help you with a cheaper more efficient thrust
Aug 3, 2009. 6:49 PMTFElite says:
Its been a week since the day you said you'd post pictures. So, where are they?
Jul 25, 2009. 6:01 PMTFElite says:
Dude. I'M 13 TOO!!!!! ANY SENSIBLE PERSON IS GOING TO KNOW THAT THIS IS NOT GOING TO HAPPEN! This isn't possible. Like I said before: Its not going to hover or even get off the ground unless you use some sort of jet fuel. NOT DIESEL FUEL! It isn't going to hover. As soon as you start to get into the air, it would go out of control. That's not hovering. That's falling with no control. If this design even remotely hovered, it would be all over the news like the hovercar shown a few years ago. And believe me, if you post a photoshopped picture, I'd know. I'm good with that kind of stuff. If its a genuine picture or video, I'll gladly accept it. It's most likely not going to happen.
Jul 25, 2009. 8:26 PMreactor011 says:
We'll right now I hope we can settle this fued and DID YOU JUST SAY I WASN'T SENSIBLE. Any way I hope we can settle this I have a lot of things to do and right now my fmily is most important.
Jul 29, 2009. 4:34 PMTFElite says:
So where are our pictures? I'm sure we'd all like to see them.
Jul 26, 2009. 1:44 PMwizerd 745 says:
Wow, this is pretty pointless, if your telling the truth, you should give us evidence!
Jul 26, 2009. 6:04 PMTFElite says:
THANK YOU!
Jul 28, 2009. 7:26 PMwizerd 745 says:
Your welcome and thank you!
p.s., I'm 15
Jul 19, 2011. 6:08 PMgrundisimo says:
The physics are impossible for a 13 year old to understand. Let alone manufacture.
Jul 9, 2010. 6:42 PMsomeperson99 says:
you cant be cooler than tony stark its just not possible
May 27, 2008. 9:34 AMgregdavidroy says:
but what does it do?
Jun 10, 2010. 5:02 PMTr1t1um1 says:
its basically a magnet and a pace maker
May 30, 2009. 1:27 PMTOMNDAN says:
the arc-reactor keeps iron man's heart working
1-40 of 191next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:mspark400
I love tinkering with anything and everything I can get my hands on. I also enjoy high adventure outdoor treks and relaxing in the shade at 14,000 ft. I am a sophomore at Rensselaer Polytechnic Inst...
more »
