Make your RC cars shocks shorter for better handling at high speeds
In this Instructable I will show you how to shorten your shocks so you can bring your car closer to the ground so you can take higher speed turns with out flapping.
I will utilize my other Instructable on how to do maintenance on your cars shocks so some of the steps will be the same.
You can find my other Instructable on shock maintenance HERE
The Stuff You Will Need:
-Shock oil ( I used 30wt)
-R/C Shocks (No duhhh =) )
-Paper Towels
-Pliers
-Fuel tubing
Step 1Taking apart your shock
Remove the spring retainer from the piston. Then remove the spring from the shock.
8 comments
Sep 4, 2011. 6:59 PMFurball_Fidelis says:
also see that peice of rubber that's supposed to act as a stopper/bumpstop on the shock shaft? remove it and you'll gain a bit more compression...I've done it to all my shocks and my crawlers crawl better and my other trucks handle better....
Dec 3, 2011. 4:18 PMFurball_Fidelis says:
the trucks are made to take off big jumps to begin with...the tires will absorb some of the impact, and if your'e racing on a track the landing ramp makes for a much softer landing,and your shocks shouldn't bottom out off a landing ramp anyways...if they are they're too soft ...if your'e bashing your truck...who cares..go with some thicker shock oil and/or stiffer springs if you're bashing
Jan 28, 2011. 1:57 PMsharlston says:
Great ible check out my rc ibles too :)
Dec 29, 2010. 6:42 AMsharlston says:
Im guessing this is why drifting/touring/street cars have smaller less travel shocks?
May 4, 2009. 8:37 AMlemonie says:
1 piece of tube and you don't have to buy new shocks? That's a neat & simple reversible mod. L
Jul 31, 2009. 3:15 AMsharlston says:
good idea thanks this helped
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:looking4ideas
