Make Your Raspberry Pi Speak
Published
Introduction: Make Your Raspberry Pi Speak
A simple method to get some feedback from the Raspberry Pi is to use Text To Speech (TTS).
I this Instructable I will show you how to do this using Python and Espeak.
Parts required:
-Raspberry Pi with internet connection (internet just for setup)
-Speaker
Step 1: Install Python
If you haven't installed Python already, install it via apt-get:
sudo apt-get install python-dev
Step 2: Install Espeak
To install the TTS engine (Espeak) and the Python module, use the following command:
sudo apt-get install espeak
sudo apt-get install espeak python-espeak
Step 3: Speak!
To speak a sentence, use the command
espeak Hello Instructables!
or in Python:
from espeak import espeak
espeak.synth("Hello Instructables!")
  • Woodworking Contest
    Woodworking Contest
  • Oil Contest
    Oil Contest
  • Clocks Contest
    Clocks Contest
13 Comments
Same problem as shiyazt and chippy johnson
Any clues as to how to fix this? Please
One issue:
when i use this command espeak Hello Instructables!
I AM GETTING THIS ERRORS ! PLZ HELP
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Hi man, I wonder if you dealt with the problem?I just get the same issue as you.Need help!please~
I also get the errors when using the command-line, but the text is spoken correctly. So I just add " 2> /dev/null" to the command to send the error messages to the bitbucket.
Also, in my experience flite (festival lite) produces nicer spoken text, but it supports less languages.
I'm getting errors in the command line but adding "2> /dev/null" isn't working
Any ideas why it only says one word no matter how many there are?
try espeak "Hello world"
I got rid of the errors by entering "start-pulseaudio-x11" prior to using espeach
Thanks homie
