Make your Xbox switch to AV mode automatically
 by Karl-Henrik
Short information about why I wrote this instruction
Did it ever annoy you that when you unlike when you start you DVD or DVB your Xbox still had you reaching for the remote to change to the AV channel? For me the main annoyance was the old TV in my bedroom, I had an Xbox with XBMC connected to it so the broken remote should not be a problem if only the Xbox would switch to the AV channel automatically. So I built this and decided to share it with you guys.
What does this modification ACTUALLY do?
It enables your Xbox to automatically switch to the correct AV channel without you reaching for the remote, it can even bring your TV from sleep mode (Well on most models)
This is done by taking 12v (or 5v) from your Xbox adding a connector to the SCART adapter and sending the voltage to pin 8. Very easy.
Step 1: What you will need
Tools you will need
1 Solder iron
1 Solder thin
1 Torx screwdriver (to open the Xbox)
1 cable cutting pliers
1 flat pair of pliers
Items you will need
50 cm(20 inches) thin red wire (For the Xbox)
50 cm(20 inches) thin black wire For the Xbox)
10 cm (4 inches) thin red wire (For the SCART Adapter)
10 cm (4 inches) thin black wire (For the SCART Adapter)
2 RCA female connectors
1 shrinkrubber or some electrical tape
1 RCA male to male cable (not include in picture)
Optional
Male to female computer drive power adapter (If you do not wish to cut cables in your Xbox)
alii says: Sep 13, 2011. 8:39 AM
Thank you brother I hope to tell us more, I am waiting for you.
alii says: Sep 9, 2011. 5:55 PM
good
Karl-Henrik (author) in reply to aliiSep 11, 2011. 2:00 AM
Thanks, hope it was helpfull to you!
Cheers.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
