Step 8A word of caution
The transformer in these UPS's are cheap. They are not designed to be run at 100% capacity for extended periods of time (such as what you will be capable of using this size battery) When I ran my UPS's at 300 watts for more than 30 minutes, the transformer melted through the case. When I pulled out my infrared thermometer it read nearly 400 degrees F!!
I had to redesign my system. I chose two UPS's that were rated at 600 watts each, but used 24 volts (2 twelve volt batteries in series). Under my new setup, I have over four hours of backup capacity as I have two car batteries.
also i have 3 PCs two with CRTs and one with 15inchs TFT how much power do i need for the whole, i am currently using 2 USPs, 1 550 VA and other is 500 Va with which i am using one to power Just monitors and others to power TFT and 3 CPS. and its working fine. (I think) i am fed up of the backup its less that 5 minutes.
please guide me.
Thanks
Gagan
India
To determine how much power you need, I recommend using the Kill-A-Watt meter (http://www.thinkgeek.com/gadgets/travelpower/7657/) to determine how much power each item draws. Be sure to measure VA, as that's what most UPS's are rated in, although Watts are useful too.
Remember, if you are going to make your UPS system last for more than the time a stock battery will last, be sure you are putting less than 50% of their rated capacity on each UPS.
Remember charging a car battery indoors can release harmful (toxic) gas fumes. Be careful where you put the batteries
Oxygen is only explosive in high concentrations, which is to say it has to be very pure to do so. Chances are, it is not going to have the correct mix for it to be combustible at any level that you could create with just 2 batteries.
Combined with the fact that it only produces these gases when it is charging and not discharging....... You should be pretty safe. Just don't keep it all contained in a super enclosed space and you should be fine.
