3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own Embossed Business Cards using Acid Etching
Step 3Getting jiggy with it.
When I made this, I had access to a really spectacular wood shop. If you happen to have a really nice table saw at home, you can make this jig without a problem, but otherwise, I'd suggest that ou skip the clamping jig, and just continue this tutorial with a pair of thick plywood sheets, and an additional brass plate, knowing that to align the brass plates and the paper sheet, you'll need to tape them together for each print you make.
I started with a sheet of .5" plywood, and a .25" sheet of PTEG. I roughed up one side of the plastic, and stuck it to the plywood with contact cement. After the glue set, I trimmed the board into two 8.5"x11" panels (the plastic sheets are there to provide a nice, flat surface to press the paper against, the wood is there to even out the pressure of the clamps, and provide integrity against warping). Then I added brass brackets along the sides to hold everything in alignment.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:bofthem(HAR.MS)
I'm M@. If you know Prototype This, TechShop, The Best of Instructables, Show Me How, or AVPII: Requiem, you've seen some of my work and the cool stuff I've been involved in. I build and design and ma...
more »
