The next part will be familiar to you if you've ever printed a circuit board. After your plate is cleaned to shiny perfection, and you've inspected your printout, it's time to adhere them together with prodigious heat. Tape the corners of the page to your brass sheet to hold it while you iron. Take special care on this step, you only have the one chance to iron this on right. Find a heat proof spot to work, such as a wooden work bench, or the concrete steps on your back porch, or an old wooden cutting board. Plug in the iron and get it ripping hot. Start pressing the iron down on the page, starting in the center, and working out. I took about five minutes to do this page, leaving the iron on one spot while pressing down, and then moving to the edges. What's happening is that the ink melts, and adheres to the board under the heat of the iron. When the paper is soaked, the paper lifts away, and the ink remains.
For another look at this method, take a look at dear Mr.
VonSlatt's webpage.
Would you mind mailing me about the keyboard key project you've been trying? I think I might be able to give you some help.
