What this instructable does:
Take a regular PR 2 bulb with a P13.5s base (i.e. those most commonly in torchlight), reuse the base and insert 3 x 5mm diameter white LEDs. See image of end result below.
The shortcut to this project is to go into a shop and buy one of these. But hey, what's the fun in that when you can make your own!
Remove these ads by
Signing UpStep 1Removing the glass bulb
The glass bulb is fused to the metal base with a clay-like cement, and should crumble easily. Once the bulb is removed, use a mini screwdriver scrape the metal base clean. The internal surface wall of the base has to be electrically conductive.
What's left is seen in the image below.
http://www.joulethief.com/kit.php
I made mine entirely from salvaged parts and wire.
Next step, to make a color-changing flashlight.. The tricky part is that the plastic base of the LEDs sticks slightly over the metal lip of the bulb, so it took some fiddling to get everything to contact properly in the flashlight I used, but it works in the end.
Nice idea -- thanks!
