Step 10Thinking about the headstock (bearings and main drive shaft)
The materials I found for this were:
Coming from an old piece of machinery, one surprisingly heavy and large sheet of metal, about 6mm thick (strong stuff!).
Two similar sized tray like pieces of stainless steel.
Some of the angle aluminum.
Old motor shaft, bearings and bearing housings.
The photos and descriptions tell it better than words up here.
One problem here is that the old motor bearings are not taper bearings - they are not designed for anything other than small loads in a sideways direction. My feeling was that this was outweighed by the fine axle and ready made bearing housings, and more importantly I had it all there and then, and it was free!
It is worth thinking about though. This is going to mean I have to be very careful and avoid certain (angry) ways of working when the lathe is in everyday use. If I find it unacceptable, or I destroy the bearings, I will replace them with taper bearings, that are much better with side loads. (see for more info on taper bearings: http://www.arceurotrade.co.uk/projects/C3_BC/pages/index.html)
Add Comment
