3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own Lathe from other peoples rubbish
Step 3Speed Control (part 2 - making a simple circuit)
The pulse-width-modulation circuit that we want can be made in a number of ways. It is essentially the same stuff that is in a light dimmer switch, all be it beefed up a bit so it can handle higher current. One might be salvaged from some other device that has speed control: many modern vacuum cleaners have one, discarded power tools would be another possible source. Really though, this would be quite a lucky find.
I chose to make my own (to better understand it and to and add some mods). It is essentially very simple and can be made using some strip board and a few cheap electronic components.
The stuff needed is as follows (maplin code in brackets):
C1 Polyester capacitor 0.1uF 250V (BX76H)
C2 Polyester capacitor 0.047uF 250V (BX74R)
C3 Polyester capacitor 0.01uF VAC (got off e-bay)
D2 Suppressor 250VAC (HW13P)
VR1 Variable resistor or POT 220k (FW06G)
R1 Min Resistor 4k7 (M4K7)
R2 Min Resistor 22k (M22K)
R3 Min Resistor 100R (M100R)
D1 Diac DB3 (QL08J)
T1 Triac BTA26-600B (UK56L) (the 16A version would suffice - I was in an overkill mood)
Some strip board to put it all on.
Optional components (more on this later):
2X Rectifier J04 (BH46A) ~ �3 each (but I got very similar ones on e-bay for 99p each)
50VA Step down transformer 240V to 9V - (search out old power supplies, audio amps, hi fi's, etc.)
The triac itself can often be salvaged from the washing machines along with the motor. I could have also ordered some spade connectors to make the 'live', 'neutral', 'the armature' and the 'stator coil' contacts, but I felt like making my own to save a few pennies (see photo). I used some standard 2mm copper wire scavenged from some old house wiring, and soldered on some cut (using a hacksaw) and flattened (hammer or vice) scrap of copper pipe.
When it comes to actually making the circuit, there is loads of good advice on soldering here on instructables, so I will not talk much about that. Enough to say that is is not a complex circuit and it should be pretty straightforwards if you read the instructions here carefully. Thanks to Westfw for the Eagle schematic 'able (http://www.instructables.com/id/Draw-Electronic-Schematics-with-CadSoft-EAGLE/).
3 comments
May 8, 2010. 7:36 AMmoshee says:
 Should I trust the values/part numbers on the schematic or the parts list? D2, R1, R2, and R3 seem to conflict.
May 8, 2010. 1:15 PMmoshee says:
Sounds good, thanks for the reply.
Great instructable, too :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:bongodrummer(Flowering Elbow Website)
BongoDrummer is founder and member of Flowering Elbow. He loves to learn about, invent, and make things, particularly from waste materials.
