3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own Roll-Up Keyboard
Have you ever wanted one of those pricy roll up keyboard but didn't want to spend the money? Here is a quick and dirty way to make your own.
Step 1Tools & Materials
Tools & Materials
For this project you will need:
1 USB Keyboard
1 Screw driver with interchangable bits
Handful of small project sized nuts and bolts
245 comments
1-40 of 245next »
Jul 6, 2011. 3:29 AMpjain7 says:
can this be done with a ps/2 keyboard???
actually i thought about this some time ago.. searched it on the net but could not find this..
Feb 6, 2012. 5:05 PMghmagm says:
YES YOU CAN! I looked it up and found a schematic! However, its quite complicated.... The 6 pins on the ps/2 each have different purposes as you may know. 4 of them are exactly like the usb. So basically, this is the usb ====.
under the first "=" that is connector/line 4. the second = is 3 and so on. on the ps/2, the plastic should be on the top. the whole entire left side is going to be used.the very top one is going to 3 on usb, the middle to 4, and the bottom to 1. on the right side, the middle is going to 2. The final connects(soldering) is gonna be fun XD GOod luck!
Jul 18, 2011. 12:32 PMdlavie1 says:
Yap it also works.
It's not about the Plug. It's just about the membrane.
PS/2 and USB are the same (most of the time)
Greetings
Oct 30, 2011. 1:41 PMschumi23 says:
Anyone know if this coul dbe done with a laptop keyboard? not USB/PSP (has ribbon cable) OK, my question is more of "are there any adapters that exist?
Jul 9, 2011. 10:56 AMfreakyqwerty says:
Does anyone know if a dogy keyboard short circuits whether It will ruin a laptop/computer or not?
Jun 16, 2011. 2:17 PMultralegomaster5096 says:
I won't save it, keyboards cost like $15 these days, and a used one might be even less...
Apr 9, 2011. 1:13 PMdarkria 45 says:
what if you put a thin platic or silicone coating on this?
Jan 22, 2008. 4:43 PMLinuxH4x0r says:
Cool! Now I have to get around to making my metal keyboard...
Jan 23, 2008. 12:55 AMgmjhowe says:
metal keyboard?? man get it done! thats the kinda thing we wanna see.
Sep 18, 2010. 6:33 AMElvenChild says:
apple keyboard with metal keys would be awesome
Jan 23, 2008. 2:32 PMalvincredible says:
amen, brotha!
Jan 23, 2008. 7:28 PMLinuxH4x0r says:
But copper is so damn expensive! (I'll try to do it this summer if I'm not too busy)
Jan 15, 2009. 9:22 AMPlasmana says:
What about copper tape?
Jan 24, 2008. 12:06 AMgmjhowe says:
copper? what about aluminium? tho if you do use copper u could always use 2p coins. (if in uk that is)
Jan 15, 2009. 9:24 AMPlasmana says:
Uhh, the newer 2p coins are copper plated steel... However, the older ones should be almost pure copper. You can test the difference by using a magnet.
Jan 24, 2008. 7:01 PMLinuxH4x0r says:
Sure! I'll use them if you can make them into sheets for me! I'll just bite the bullet and get some.
Jun 12, 2010. 1:55 PMfirelord88 says:
or you could just go to a computer store pick up a roll out one for $15
Jul 8, 2010. 8:06 AMRedgerr says:
thats 15$ more than you need to spend if you happen to have a keyboard laying around... its also cooler if you said you built it yourself and it works! thats my opinion anyhow
Jul 21, 2010. 8:49 AMipwnuall2 says:
hahaha boned.... Just Kidding! ;)
Jan 30, 2008. 2:56 PMMaxaxle says:
That looks like the kind of thing that I would do on the weekend! But I don't wanna let go of my decent, although basic, keyboard quite yet. Besides, I prefer to use buttons over thin, touch-sensitive pads that leave your fingers sore from bumping the desk so much, lol .
Dec 6, 2008. 3:32 AMKryptonite says:
Hey, do you do HTML coding? just the way ou wrote <sarcasm> lol </sarcasm> is the same as you do affects and stuff when writing out a web page. The reason I ask is because if you do, I'd dearly like some tutoring. =P
Feb 9, 2009. 1:00 PMcyrozap says:
Use Wikipedia.
Feb 13, 2009. 1:57 AMKryptonite says:
Jee, thanks for all that amazing help...
Apr 9, 2010. 5:02 PMloofkid says:
 w3schools.com/html/default.asp has a very good tutorial. thats how i learned.
Apr 12, 2010. 3:20 AMKryptonite says:
I started web design this year, and that's the website we use mainly!
Feb 14, 2009. 3:18 PMcyrozap says:
You're VERY welcome!
Apr 3, 2010. 12:11 AMjsvanriet says:
hey just out of curiosity...You know how the sell silicon that people can use like artists and stuff to create molds and what have you not?  What if you placed this INSIDE of the silicon inside a mold as it was curing?  Anyone got any ideas/willing to be the guinea pig?  I have heard about silicone molds but have never tried or even know where to start...just throwing the idea out there for the more accomplished/inventive community members.
May 13, 2009. 9:34 PMYellowsmiley says:
One thing, the contacts on the circuit board and the keyboard membrane don't hold tightly together with anything i've tried (superglue the edges of the circuit board and the membrane, electrical tape). Anyone got any ideas?
Nov 24, 2009. 7:15 PMkingsmanname says:
Umm Maybe Hot Glue? It Does Wonders!!!
Oct 8, 2009. 1:57 PMscratchr says:
wire glue click here but carful it is unforgiving.
Jun 14, 2009. 12:22 PMAzayles says:
melt the three layers together at strategic points using a soldering iron and an old bit.
Aug 23, 2009. 4:32 AMAwajiMan says:
This is a great idea, but keep in mind that the labels for keys should be the size of the holes in the membrane contacts, not the size of the physical keys on the keyboard. For example, the space bar sits on top of a contact the same size as all the other keys on most membrane keyboards, and you would have to aim for that exact spot instead of the area where the space bar would normally be. Same for shift, tab, any other non-square key. Would require a lot more accuracy, and probably be slower to type on at first.
Jun 23, 2009. 2:13 AMthisiswhatwecalltragedy says:
What kind of feedback should I expect? Do you press as hard as you would with a regular keyboard, not as hard, harder..?
Mar 8, 2009. 9:46 AMr0b3r7 says:
I need Help! I went out and got a cheap keyboard to see if this would work, and if it did use it because this idea is frikkin sweet. The keyboard i used is a Dynex multimedia keyboard, and it's frankly, not working too well, but that's because of me. One of the wires connecting the control board to the wire to the usb broke loose, and I'm trying my best to fix it. And, because I'm stupid i tried using superglue to get it back together, before realizing that superglue doesn't conduct electricity. What i need is for anyone to tell me if this project is beyond redemption and if it isn't howto fix it. thanks to anyone who helps
Mar 8, 2009. 9:49 AMr0b3r7 says:
I forgot to mention that i didn't actually connect the wire, i saved it just in time, thought superglue is all over the place where the wire connects to the control board. Please excuse my double posting
Jun 21, 2009. 6:50 PMA.C.E. says:
reassemble it as good as you can and return it. say it is dead.
Mar 28, 2009. 6:18 PMmatstermind says:
solder it. wires are pretty easy to solder together.
Nov 23, 2008. 7:40 AMRicaPower says:
can u use like 3 of the "membranes" to make a thick sturdy skin?
May 11, 2009. 10:36 PMYellowsmiley says:
Potentially you could, but all 3 membranes would need to be of the same brand and the circuitry needs to look the same, also your key reaction/your keys ability to actually react will decrease.
Dec 6, 2008. 5:38 AMcd41 says:
howed you print the key labels if you already took the keyboard apart?
1-40 of 245next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:Auger Duval
