So I found this Lindsay Press deal about how to make your own soda.
http://www.lindsaybks.com/prod/index.html
There are three options
1. Spend a lot of money and buy a commercial soda fountain or it's parts. Expect to pay at least $200 even on ebay for a carbonator unit (a pump and a chamber probably without regulators)
2. Ferment. Take sugar water, add yeast and wait. This is definitely the lowest cost solution, but I don't like to wait.
3. Follow the instructions that follow
4. OK There is a fourth option: Buy the premade stuff (but hey, this is "instructables" right? We like to Do it ourselves.
So Stuff you will need: CO2 canister - If you can't afford one (or don't drink enough beer to have a kegerator) then troll the streets. Restaurants often leave these out in back to be exchanged with new ones. Choose a large chain restaurant to steal from. No, don't steal. CO2 is useful for other projects. Buy a cylinder. They last a long time (essentially forever) You will need to buy a regulator. $40. buy a new one.
Remove these ads by
Signing UpStep 1Gather Materials
So gather your materials:
*Plastic 2-liter bottles - they must have that ring below the neck
- There are 2 neck sizes , and I have built this for the smaller, more common size.
- Metal plate - about one square foot should be plenty. Stainless steel is probably ideal. I used plain old mild steel, and aluminum could work if it's thick enough not to bend easily.
- Pipe Fittings - I'm using 1/4" pipe fittings
- short nipple (i used brass)
- valve (also brass)
- quick disconnect air fittings (2 male, 2 female) and some air hose
- teflon tape
- CO2 cylinder ( you can get a very small one which will last a good long time at a beer brewing supply store, or a welding supply store)
- CO2 regulators (also available at brewing supply store or welding supply store)
- wing nuts and carriage bolts (1/4" are good) about 2 inches long.
- some kind of gasket material. -- silicon aquarium sealant is probably best, but I have used bike innertube successfully
http://www.harborfreight.com/regulator-gauge-94841.html
or
http://www.harborfreight.com/oxygen-regulator-94846.html
I would assume this hose would work since adding the pressure from the regulator doesn't excede 90PSI?
http://www.harborfreight.com/1-4-quarter-inch-x-25-ft-self-coiling-air-hose-47.html
Thanks!
http://www.instructables.com/id/DIY-Soda-Water-%26-Home-Carbonation---Pays-For-Itsel/
Is better, easier, and cheaper.
1 - A navy CO2 extinguisher, looks and feels like older diving heavy air tanks
2 - An empty water extinguisher with a build in pressure gauge and tire valve and rated refillable. (big silver stainless steel ones that spray water under air pressure)
3 - A few new high pressure propane hoses with air valves for filling tire.
4 - An access to brass fittings for conversion and etc.
Can I put a tire air filler on the CO2 bottle and Carbonate water in the water silver container and shake it after the pressure guage reach 100 psi, (recommend refill pressure)?
The key concern is skipping the regulator. Larger canisters seems to reach over-pressure limits at a slower safe speed while watching the pressure gauge
It is not safe as a routine without a regulator but maybe monthly with a clear head and cold CO2 tank?
I do not have money to go shopping and I am dying for carbonation. That would be a luxury.
http://www.instructables.com/id/EKWAN4FF44XY58J/
Last month, I happened across an incredibly detailed essay on carbonation by Richard Kinch, without which I could not have completed my project...I highly suggest reading over his opus before embarking on your own carbonation exploration.
http://www.truetex.com/carbonation.htm
