3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own Soda - - Cheap!
So I like carbonated beverages. Soda, Beer (especially beer), Champagne, whatever bubbly.
So I found this Lindsay Press deal about how to make your own soda.
http://www.lindsaybks.com/prod/index.html
There are three options
1. Spend a lot of money and buy a commercial soda fountain or it's parts. Expect to pay at least $200 even on ebay for a carbonator unit (a pump and a chamber probably without regulators)
2. Ferment. Take sugar water, add yeast and wait. This is definitely the lowest cost solution, but I don't like to wait.
3. Follow the instructions that follow
4. OK There is a fourth option: Buy the premade stuff (but hey, this is "instructables" right? We like to Do it ourselves.
So Stuff you will need: CO2 canister - If you can't afford one (or don't drink enough beer to have a kegerator) then troll the streets. Restaurants often leave these out in back to be exchanged with new ones. Choose a large chain restaurant to steal from. No, don't steal. CO2 is useful for other projects. Buy a cylinder. They last a long time (essentially forever) You will need to buy a regulator. $40. buy a new one.
Step 1Gather Materials
Gather Materials
I chose this method since I had a CO2 cylinder, regulators, hoses, fittings and whatnot already in my possession. If you don't have stuff like that, then fear not. The total cost will still be less than that of the in-line carbonator devices.
So gather your materials:
*Plastic 2-liter bottles - they must have that ring below the neck
  • There are 2 neck sizes , and I have built this for the smaller, more common size.
  • Metal plate - about one square foot should be plenty. Stainless steel is probably ideal. I used plain old mild steel, and aluminum could work if it's thick enough not to bend easily.
  • Pipe Fittings - I'm using 1/4" pipe fittings
  • short nipple (i used brass)
  • valve (also brass)
  • quick disconnect air fittings (2 male, 2 female) and some air hose
  • teflon tape
  • CO2 cylinder ( you can get a very small one which will last a good long time at a beer brewing supply store, or a welding supply store)
  • CO2 regulators (also available at brewing supply store or welding supply store)
  • wing nuts and carriage bolts (1/4" are good) about 2 inches long.
  • some kind of gasket material. -- silicon aquarium sealant is probably best, but I have used bike innertube successfully
70 comments
1-40 of 70next »
Feb 12, 2011. 3:58 AMhossmonkey says:
Can either of these regulators from Harbor freight be used for the project? If not could you explain why?
http://www.harborfreight.com/regulator-gauge-94841.html
or
http://www.harborfreight.com/oxygen-regulator-94846.html
I would assume this hose would work since adding the pressure from the regulator doesn't excede 90PSI?
http://www.harborfreight.com/1-4-quarter-inch-x-25-ft-self-coiling-air-hose-47.html
Thanks!
Dec 22, 2007. 7:22 PMtradergordo says:
The method in this instructible:
http://www.instructables.com/id/DIY-Soda-Water-%26-Home-Carbonation---Pays-For-Itsel/
Is better, easier, and cheaper.
Nov 18, 2010. 6:56 PMbluefringes says:
I disagree because the tire valve is made with copper that is not food-grade. It contains lead and it will leach it into your drinks.
Apr 26, 2010. 2:44 PMfiducianullus says:
lol - be nice dude.
Dec 24, 2007. 1:39 PMtradergordo says:
Sorry, was just putting the comment there for someone that might be looking to do home carbonation so they knew there was easier ways. I don't know why people make this more complicated than they have to. Heck even the other instructable makes it more complicated than it has to be. Just stick a 1/4 inch barb onto your regulator if it doesn't already have one, attach a tube, and stick a 99 cent tire inflater on the end of the tube. Then stick a cheap schrader valve in a plastic soda bottle cap and you are done. You can carbonate any liquid in about 5 seconds. Better, easier, cheaper, faster, whatever...
Nov 18, 2010. 6:53 PMbluefringes says:
Yeah, except that the copper in the tire valve is not food-grade copper. It contains lead and will leach lead into your drinks. Toxic stuff!
Sep 11, 2008. 8:36 PMJwoody69 says:
I noticed in the original article that a kegerator is referenced but I have also noticed that soda regulators have pressures of 160 PSI but beer regulators only go to 60 PSI. I have found really nice beer regulators at some of the lowest prices at www.kegcowboy.com but they only sell beer regulators and beer kegerator equipment. Is it enough for soda too?
Sep 12, 2008. 7:16 AMtradergordo says:
60 is plenty. A two liter soda bottle is supposed to be able to handle up to 200 psi but in testing they can burst around 140 psi. Of course in the real world you don't want to get anywhere near their burst point. Most people do not like having more than 30 psi carbonation for their soda, and commercial soda products never exceed 30. Its actually hard to drink (and annoying) at much higher levels of carbonation (you'll be burping continuously).
Sep 12, 2008. 8:22 AMJwoody69 says:
hmmmm maybe I do need a soda regulator so I can make some special 120 psi soda for my mother-in-law and sit back and watch the show.....
Apr 26, 2010. 2:43 PMfiducianullus says:
This can be done with dry ice too. Maybe I'll  'ible that
Dec 7, 2008. 5:14 AMloqk says:
By the way, I notice a lot of people seem to carbonate warm liquids. It is known that gasses (non polar) dissolve more readily in cold water and salts (polar) dissolve more readily in warm water. So for maximum absorption of CO2, make sure your drink is ice cold before adding CO2
Sep 30, 2008. 4:57 PMnanonot says:
Can i use any kind of tubing from the CO2 tank to the bottle?
Jul 9, 2007. 7:27 PMBuilderboY says:
haha, is that that one effect in photo booth?
Jul 31, 2008. 10:40 AMOompa-Loompa says:
ya i saw that on my mom's new laptop.
Jul 30, 2008. 12:29 PMdave48858 says:
perfectly safe as far as the bottle holding up, I put 180 pounds on my setup (20 oz, 1l, 2l, & 3l bottles). your contraption for the top, I'm not too sure about. when I made mine, I just used a valve stem, took the valve out, drilled a small hole through the cap, attached the valve stem there, 1/4 in hose to a couple ball valves and it worked fine, much cleaner and quicker. also turning the bottle upside down in introducing the co2 made it carbonate much quicker. best of luck, Dave
Jul 19, 2008. 8:57 AMMatt D655 says:
you should use a mix of 70% nitrogen and 30% Co2 for crbonation, co2 is ok but nitrogen is better.
Jul 21, 2008. 4:56 PMsneigke says:
Oh, and it's the CO2 which actually carbonates, not the nitrogen...
Jul 21, 2008. 4:55 PMsneigke says:
For Guiness, yes... Soda... NO! The N gives Guiness beer that heavy, lingering, cool looking head. I don't think I'd want that in my rootbeer!
Jun 23, 2008. 7:32 PMWired_24_7 says:
wow... that video looks pretty dangerous! Not sure if I would try that without protective gear, you have a little bottle rocket in your hands.
Feb 23, 2008. 11:34 AMcasper.707 says:
I are ben, you are cheap! A pack of napkins is only like two dollars at wally world
Feb 29, 2008. 5:33 PMi are ben says:
what is a good brand of napkin then?
May 26, 2008. 10:33 PMRishnai says:
The kind that doens't look like truckstop toilet paper--a.k.a. 40-grit, translucent, and won't absorb anything. If it looks fluffy, it's probably a good napkin. Get six dollars together and buy three brands if you're not sure.
Feb 10, 2008. 12:31 PMi are ben says:
Were can I purchase a napkin without buying a whole pack?
Apr 1, 2008. 7:16 PMJames (pseudo-geek) says:
HHAHAHAHAHAHAHA try wendy's, McDonalds, or any other fast food resteraunt, they give them out free.
Jan 17, 2008. 10:53 AMValdezB says:
Your loundry dryer sounds great :)
Dec 26, 2007. 6:48 PMcprmichael says:
Two quick comments. 1) Keep in mind while shaking that even though it's a closed pressurized system, gravity is still in effect and if you shake the bottle higher than the regulator, the "water" will tend to run down the tube and into the regulator where it (conceivably) could mold and contaminate the next batch. I learned this the hard way, carbonating home brew. 2) Keep an eye on the regulator pressure and resist the temptation to crank the pressure way up for a quick carbonation. I don't know the bursting pressure of a PET bottle but when they go, they tend to explode big time.
Jul 5, 2007. 1:24 PMdavidlaska says:
I have these parts:
1 - A navy CO2 extinguisher, looks and feels like older diving heavy air tanks
2 - An empty water extinguisher with a build in pressure gauge and tire valve and rated refillable. (big silver stainless steel ones that spray water under air pressure)
3 - A few new high pressure propane hoses with air valves for filling tire.
4 - An access to brass fittings for conversion and etc.
Can I put a tire air filler on the CO2 bottle and Carbonate water in the water silver container and shake it after the pressure guage reach 100 psi, (recommend refill pressure)?
The key concern is skipping the regulator. Larger canisters seems to reach over-pressure limits at a slower safe speed while watching the pressure gauge
It is not safe as a routine without a regulator but maybe monthly with a clear head and cold CO2 tank?
I do not have money to go shopping and I am dying for carbonation. That would be a luxury.
Nov 19, 2007. 1:16 PMkamu11 says:
You do not add any chemicals or anything at all to a fire extinguisher filled with co2. The co2 for fires and carbonation are exactly the same
Jul 28, 2007. 11:40 PMdavidlaska says:
I found some information about people buying old CO2 extinguishers and using them up and changing the valve of the bottle. My project worked, but I never did get the it as bubbly stating as soft drinks.
Jul 6, 2007. 11:59 AMdavidlaska says:
I did it and I liked seeing it done in person. I did remove the stop in the tire filler so the CO2 canisters hose would not blow (since it was designed to direct co2 out. But the water extinguisher is leaky and now I am worried about what the Navy added to the their extinguishes 40 years ago.
Apr 23, 2007. 4:46 PMLasVegas says:
Great Instructable. I have to say, I was a bit disappointed. The first picture was that of a modified refrigerator, much like what my dad had done. Instead, it was a cool way of processing a 2 liter bottle. Good idea, but the 1st picture doesn't show it. I suggest adding a picture of a class a iced charged (soda) water with a slice of lemon or lime as the intro picture. I've been wanting to repeat my dad's process for years. I even bought an old refrigerator for that purpose. It's been sitting on my back porch for about 10 years now... I think I'll need a new one.
Sep 27, 2007. 6:43 PMsqueakpickle says:
Augh! I was swearing to a friend that I would be able to find an instructable for a kegerator, and your mention is the closest thing on the site. So, pretty please, post a kegerator instructable, or I may never be able to face my again.
Apr 27, 2007. 2:10 PMPunkguyta says:
You mean you run the pop through the comprressor? That can't be good seeing as you probably wouldn't be able to get all the freon out?
Apr 27, 2007. 3:26 PMLasVegas says:
Absolutely not! The fridge is simply used as a cooling device. The CO2 tank is kept outside and lines are run into the refrigerator to charge two cans of water. Another line from the cans is fed out of the refrigerator to the tap (replaced the rinse attachment on the kitchen sink).
Apr 28, 2007. 1:39 AMPunkguyta says:
Oh, I was going to say there for a moment "what the fuck?". I get it now though, sorry about that.
Aug 21, 2007. 12:06 PMchickenliver123 says:
not cheap... expensive
Jul 25, 2007. 3:45 PMletsapocalypso says:
Looks interesting...I've come up with my own instructable with a different method (using a tire chuck and valve)...check it out, and let me know what you think!
http://www.instructables.com/id/EKWAN4FF44XY58J/
Last month, I happened across an incredibly detailed essay on carbonation by Richard Kinch, without which I could not have completed my project...I highly suggest reading over his opus before embarking on your own carbonation exploration.
http://www.truetex.com/carbonation.htm
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:juggler
