3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own Soda - - Cheap!
Step 5Make soda
Make soda
so now you are ready to make it.
Get your bottle of water from the fridge.
Open the cap
Attach the assembly and screw the clamping screws on tight. Just tight, not overly tight.
close the valve
attach the CO2 line
open the tank valve
adjust the pressure on the regulator to about 50 PSI
open the valve on the bottle.
Check for leaks, and hisses.
Shake the bottle for about 30 seconds to a minute (more shaking == more fizz )
close valve on bottle.
Disconnect quick-release
close CO2 tank valve.
open bottle valve slowly
remove assembly
enjoy bubbles.
3 comments
Dec 7, 2008. 5:14 AMloqk says:
By the way, I notice a lot of people seem to carbonate warm liquids. It is known that gasses (non polar) dissolve more readily in cold water and salts (polar) dissolve more readily in warm water. So for maximum absorption of CO2, make sure your drink is ice cold before adding CO2
Jul 30, 2008. 12:29 PMdave48858 says:
perfectly safe as far as the bottle holding up, I put 180 pounds on my setup (20 oz, 1l, 2l, & 3l bottles). your contraption for the top, I'm not too sure about. when I made mine, I just used a valve stem, took the valve out, drilled a small hole through the cap, attached the valve stem there, 1/4 in hose to a couple ball valves and it worked fine, much cleaner and quicker. also turning the bottle upside down in introducing the co2 made it carbonate much quicker. best of luck, Dave
Jun 23, 2008. 7:32 PMWired_24_7 says:
wow... that video looks pretty dangerous! Not sure if I would try that without protective gear, you have a little bottle rocket in your hands.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:juggler
