Make Your Own Thirsty Plant Graph!
620
5
Posted in TechnologyKits
Introduction: Make Your Own Thirsty Plant Graph!
About: Technology Will Save Us is a haberdashery for making technology in everyday life. We design, manufacture and sell DIY technology Kits and run workshops to help people become makers and creators of technology...
In this Instructable we’ll use Arduino and Processing to plot a graph with our moisture sensor, to see the relationship between the MOSFET transistor and the sensor.
You will need:
DIY Thirsty Plant Kit
DIY Start Arduino Kit
Some jumper wires and/or crocodile clips
We’ll also be using Arduino software (www.arduino.cc) to read the Thirsty Plant and Processing (www.processing.org) to plot the graph.
Step 1: Setting Up the Hardware: Part One
Setting up: In our experiment we started off with a dry moisture sensor as it’s much easier to get the sensor wet than to dry it out!
To attach your Thirsty Plant to the Arduino you will need to run a jumper wire (preferably red) from the point where the resistor meets one side of the moisture sensor and the left leg of the MOSFET transistor.
To do this, push the jumper wire through the front of the Thirsty Plant, through the hole marked with the ones and zeros symbol. Then twist these wires together at the back. Attach the other end of this (red) wire to Analog Pin 0 on your Arduino.
Step 2: Setting Up the Hardware: Part Two
We will need to ground the Thirsty Plant as well, this is to understand when there is power flowing through the LED.
To ground the Thirsty Plant, attach a jumper wire (preferably black) to the negative leg of the LED. Again, push the jumper wire through the front of the Thirsty Plant, through the hole marked with a ground symbol (three lines). Again, twist these wires together at the back. Plug the other end of this jumper wire (black) to a GND pin on the Arduino.
Step 3: Coding With Arduino
Arduino:
We’ve attached our thirsty plant to analog input pin A0 so we’ll now need to write a sketch that takes a reading from that pin. In this sketch we’re reading the value from pin A0 and printing the values to Serial(9600).
char separator[] = " | ";
void setup()
Serial.begin(9600);
void loop()
int sensorValue = analogRead(A0);
Serial.print("Thirsty Plant"); //Label for the sensor
Serial.print(":"); //Seperator between values
Serial.print(sensorValue, DEC); //Actual value
//You can add in this part of the code if you want to monitor more than one Thirsty Plant
Serial.print(separator);//Separate different readings
int sensorValue2 = analogRead(A1);
Serial.print("Thirsty Plant 2"); //Label for the sensor
Serial.print(sensorValue2, DEC); //Actual value
int sensorValue3 = analogRead(A2);
Serial.print("Thirsty Plant 3"); //Label for the sensor
Serial.print(sensorValue3, DEC); //Actual value
Serial.println();
Step 4: Using Processing to Make the Graph
Processing:
If you haven’t used Processing before you can download the software from www.processing.org. Processing is very like arduino but its outputs are image based rather than hardware based. Processing will take the information we’ve printed to serial(9600) and use it to plot a graph.
Our sketch may look quite complicated but it allows the sketch to read multiple Thirsty Plant inputs and put all the graphs on one page. Read through it to see how it is working.
import processing.serial.*;
Serial myPort;
String delimiterBetweenMultipleValues = "|";
String delimiterBetweenLabelAndValue = ":";
int numserialreads=0;
int graphStartX = 100;
int textPadding = 2;
int circleDiameter = 3;
String[] valuePairs;
boolean drawPoint = false;
boolean drawCircle = true;
boolean drawLine = true;
int xPos = graphStartX; // horizontal position of the graph
int partH; // partial screen height
int valmin = 0; // Minimum Value of Graph
int valmax= 600; //Maximum value of Graph
void setup()
size(1366, 700); //adjust to your screen size
println(Serial.list()); //Get Serial Setup
myPort = new Serial(this, Serial.list()[0], 9600); //Open Serial Port at 9600
myPort.clear(); //Empty the Buffer
myPort.bufferUntil('\n'); //Don't generate a serialEvent() unless you get a newline character:
background (170, 219, 207); //Initial Background Colour
textSize(42); //Text Size
fill (237, 61, 138); //Font Colour
void draw()
//Everything happens in the serialEvent()
void keyPressed() //This will let us refresh the screen when he hit the 'n' key
if (key == 'n') {
xPos = 0;
background (170, 219, 207); //Wipes screen with turquoise background
void serialEvent (Serial myPort)
String inString = myPort.readStringUntil('\n'); //Get ASCII String:
if (inString != null) {
numserialreads++;
inString = trim(inString); // Trim off any white space
println(inString); //Show the incoming data string
if (numserialreads<20) //Reset Everything
println("initializing");
return;
if (numserialreads == 20) //Reset Everything
xPos = 0; //Return to 0 position
background(170, 219, 207, 255); // Clear screen and show turquoise background
valuePairs = split(inString, delimiterBetweenMultipleValues); //split incoming string into pairs of label/value and store in an array.
int totalinputs = valuePairs.length;
partH = height / totalinputs; //Divide screen up by number of sensors
for (int j=0; j
String[] pair;
pair = split(valuePairs[j], delimiterBetweenLabelAndValue);
String label;
label = pair[0];
text(label, 10, partH*(j+1) -10);
pair[1]=trim(pair[1]);
int value = int(pair[1]);
value = int(map(value, valmin, valmax, 0, partH)); //Map the value to the variable partial heights
if (j==0){
stroke(245, 230, 86);
if (j==1){
stroke(241, 90, 49);
if (j==2){
stroke(0, 173, 181);
line(xPos, partH*(j+1), xPos, partH*(j+1) - value); //graph its value
stroke(255); //dividing line colour
line(0, partH*(j+1), width, partH*(j+1));
if (xPos>= width)
xPos = 0;
} else
xPos++; //increment the graph's horizontal position
void exit() {
myPort.stop();
Step 5: Verify, Upload and Experiment!
Verify and Upload: Once you are happy with both your sketches upload to Arduino. Once your Arduino sketch is loaded you can press the Run button in processing to see your graph. Make sure your serial monitor in your Arduino application is turned off, otherwise Processing will not be able to read the serial port!
If you sensor is totally dry the graph should be quite high. If you pick it up in your hand so that you touch both of the nails you should see your graph begin to drop.
The peaks you see in your graph when it’s at its tallest are from the blinking LED, the peaks should correspond to the flashes it is making.
Place the sensor in a plant pot, water it, and watch the graph descend.
You can use this data to do many different things, maybe see how long it takes your soil to dry out, make your plant talk by tweeting you when it’s dry, or maybe try changing the resistor in your Thirsty Plant to see if it affects how dry your soil can be!
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
