Step 2: Soldering is fun!
Just solder the shown colors to the right pins. Good luck with the bridge for pins 5, 10 and 8, naah it's not really that hard =)
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Amazon has a hdmi to cat 5 convertor that supports full 1080p that claims to work at 100ft. It's "Passive" as it only uses the build in power output of your videocard.
May purpose to this is to Always run the CPU and only Blank the screen if nobody used or force to blank screen to stop the user.
NOTE : I will used relay to ON/OFF this LCD by separate control. Through opening of contact of 1 of the 15 pins.
my problem is I dont know which pins is i will going to control OFF/ON.
Hoping for your future answer..
Thanks !
GOD BLESS..
Too much ado for a simple extender, for me, but it's useful for a lot of people, kudos to you.
However, if you are able to connect a computer to that screen temporarily with a normal VGA cable (or hdmi, dvi), it is possible to "read" this info from the monitor, save it and then force it on your computer so that you will get the correct resolution and other settings when you connect your screen with a UTP hacked cable. Please see the full instructions at the above link as well as all the warnings there! Trust me it is not difficult, please see below:
Warning:
Prerequisites
Read and understand what you are doing. Visit the link above for more info
Don't blame me when you ruin your $3000 HDTV. Smoke CAN happen.
Don't edit the settings you extract unless you know what you are doing!!!
Procedure
0) Connect the monitor with a proper VGA cable, or any other cable that your tv/monitor accepts, e.g. hdmi, dvi,
1) Download Phoenix.zip and extract it to a working folder.
2) Run it and click the registry toolbar button.
3) You don't need to edit the settings, unless you are feeling very brave and want to try to force non-standard resolutions or refresh rates - please see the main link at the top for more info
4) Save the EDID to a .DAT file in the working folder.
5) Connect the monitor with your hacked VGA/UTP cable
6) Download moninfo.exe and install it.
7) Open the saved .DAT with MonInfo and make sure it doesn't complain about it - if it does, please see the link at the top
8) If MonInfo reads in an displays the settings the way you configured them in Phoenix then...
9) Select Create INF... from the file menu and save it to the working folder.
10) You can edit the INF if you are feeling brave (see disclaimers!)
11) Open Start, type devmgmt.msc and press Enter.
12) Select the monitor you want to change, right click and select Update Software
13) Use the tried and true "Have Disk" method to select the INF and install it (don't forget to confirm that you are happy to install an unsigned driver).
14) Reboot and enjoy the proper resolution!
Most of the info is c/p from the source link, all credit goes to the author of that tutorial!
On a different note, all VGA cables I've seen in my life feature ferrite cores for interference protection. I don't know whether it needs to be installed, or whether the twisted pairs in the UTP cable should do the job?! Any ideas?
qvs.com search MSV12
means vga port - cat5 - vga port
