Make your own cnc controller
Build your own CNC controller for next to nothing from rubbish
You can build your own CNC controller for a HM30 or Junior mill. The CNC controller is able to move the table at a max rate of about 200-300 mm/minute.
The controller is built basicly from parts from a fisher and pykel washing machine from the tip. Three motors are required.
Step 1Connecting stepper motor to milling machine
connecting stepper motor to milling machine
Finding the stepper motors
The motors from a fisher and pykel washing machine are removed along with the control board. Three motors are required.
Connecting the stepper motors to the HM30 machine
The hole at the end of the plastic housing the motor spindle, slips over the end of the x,y axis on the mill table. The spindle is shortened and drilled to allow the shaft from the table to slide into the shaft from the washing machine. A tapered pin and hole, hold the two together.
49 comments
1-40 of 49next »
Dec 1, 2010. 2:44 AMalexis_4315 says:
Very Impressive Idea...
Oct 29, 2011. 2:04 AMnicolas.k says:
Excuse me ,r u a university student? oh , Trick or treat, haha!
Dec 12, 2011. 5:57 PMamcmahon says:
YOU FAIL! haha
Oct 29, 2011. 9:17 PMalexis_4315 says:
what ever.
Sep 4, 2011. 7:21 PMCNCmakers says:
Cool, you are better, how about the accuracy after your work done? what we do is just replace the original CNC control and AC servo motor & drivers. here is our work of retrofitting a second hand Mori Seiki CNC lathe: http://www.cncmakers.com/cnc/Tech_Support/CNC_machine_retrofitting.html
Mar 13, 2011. 2:44 PMSubMicro says:
Great instructable but seems to leave out allot of detail needed to replicate.
Feb 8, 2011. 4:52 PMJkirk3279 says:
"So I added a couple of input contacts that are activated from a sliding rod that give feed back as to when the table is moving, and it virtually gives me no error (step size is 0.0179mm)."
You mean you bought an official kit, like from NewAll ?
That would explain the precision. About the only way to beat the backlash in an older machine.
Dec 30, 2010. 8:13 AMdjinn1987 says:
good guy so good i am from China ,"come on" chinese is<  ¹- jiayou>
Jun 4, 2010. 3:36 PMMudsucks says:
Great Idea charcoal999, But I looked at your driver circuit and don't understand why you didn't use the washing machine driver itself. It takes mains ac and rectifies it to a dc bus voltage then chops it up to drive the three phases of the motor at up to +/- 1200rpm. The input to the driver section could be cut free from the washing machine cpu and fed directly from a breakout board or cheap micro-controller. Regards Mudsucks.
Apr 4, 2010. 4:09 AMkeioku says:
Great Cool Instructable
I hope more information about  your comment.
How does it (a sliding rod) works ) ?
----------------------- your comment -----------------
Oct 4, 2009. 8:32 PMwhitworthsocket says:
Charcoal, "Im Inspired". I am familiar with the Fsher And Paykel motors. Through research on using them as wind generators. There are a few different models what model did you use? Where can I download your CNC software? Keep up the good work REgards Whitworthsocket
Sep 16, 2009. 4:53 AMSeaCaptain says:
I absolutely love Instructables, because of people like you who are willing to share their excellent information! Thank you! This looks like a great project which I just might try.
Apr 18, 2009. 8:32 PMfgleich says:
Why did you not use the linux software, EMC ? FREE FREE FREE
Jun 24, 2009. 8:04 PMmrwolfe says:
A switching current regulator would be better. You could use a 555 or an LM317 to turn M1 off for 10us or so when the current hits 2.1A. If you get it right the average current will be 2A, and it will have a high risetime.
May 31, 2009. 5:02 PM4star says:
does and one know how how the 2axis cnc can be controll through a high level prog language like C/C++.
Dec 16, 2008. 4:28 AMJorLouJr says:
What´s the motor resolution (how many steps per turn) ?
Dec 16, 2008. 4:22 AMJorLouJr says:
TurboCNC would fit the bill pretty nicely ... it´s free and can run on very old PCs ... www.dakeng.com
Oct 16, 2008. 11:40 PMbishopdante says:
All those lovely old machines that can be robotised. Yeah. The future lookin' GOOD.
Feb 16, 2008. 10:12 AMivanirons says:
Cool Instructable. You are very creative and technical. I like the electrical schematic. Very helpful.
Good work,
Ivan Iron
CNC Video Tutorials
http://www.cncinformation.com
Mar 5, 2008. 8:03 PMpanic mode says:
it is a cool instructable and i don't mean to be negative but schematic is not complete and it has few things that need to be corrected. for example shown diodes in bridge rectifier are way to small for the job and AC is not connected properly to bridge.
Jan 29, 2008. 8:17 AMgkimber2 says:
I know this is off topic, but did anyone notice that if you use a wheel mouse to scroll paste the first picture the disk on the right side of the photo appears to rotate? You have to hold your eyes still and roll the page up and down.
Feb 15, 2008. 11:49 PMwbreslin951 says:
ur on crack lol. jk bro.. i tried it and didn't see nothin
Jan 31, 2008. 5:52 PMdavebrown says:
you're right... good call
Jan 26, 2008. 4:15 PMGorillazMiko says:
Oh wow... dang... nice job, this is very nicely done. Great schematics, great pictures, looks like A LOT of work.
Feb 1, 2008. 8:30 PMguyfrom7up says:
I've made something similar, instead I used some 4-axis divider and I used 4 PicStep drivers. Etching the boards were terriable. transfering the toner, soacking it, hours hunched over the sink removing little bits of paper between fine traces with a tooth pick. Hunched over the sink more, swishing the etchant. Hunched over, drilling hundereds of holes. sitting, soldering hundereds of joints. soldering 160 leads for data and power cables, it was terrible. Hopefully when I'm done with my 36 volt, 8 amps power supply I can finally test all of my stuff!
Jan 25, 2008. 9:13 PMthebboy says:
what does cnc mean
Jan 25, 2008. 9:33 PMwiml says:
it stands for "computer numerical control", it just means a computer-controlled milling machine or other shop tool.
Jan 26, 2008. 6:56 AMthebboy says:
oh thanks. this looks really cool, but wouldn't serve someone like me any use.
Feb 1, 2008. 9:02 AMTrent The Thief says:
It might not. But learning how to program one using Logo or other controller language could come in handy sometime. I once took a part time job and ended up writing scripts for a machining laser that cut out pieces for microwave filters and amplifiers. Anytime you can get a chance to learn something cool you ought to take it. Ya never know. Besides, you could build it and sell it to some woodworker to run his router.
Feb 1, 2008. 3:10 PMthebboy says:
too complicated for a kid like me.
Feb 1, 2008. 5:57 AMflattop says:
Are they stepper motors or brushless DC, kinda like an enormous CD-ROM motor? Or are the two pretty much the same thing? You've got me wondering if you could make those into hub motors for an electric bicycle or cart.
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:charcoal999
