For this to have a nice effect you need loads of different color LEDs.
I found it a bit frustrating to find colored LEDs. And when I found them they were more expensive then a normal white LED.
Thats why I thought there had to be an easier and cheaper way. Though thinking about it for a long while the answer was more simple then I thought.
Follow these simple steps to create your own colored LEDs!
Remove these ads by
Signing UpStep 1Materials & Tools
- White LEDs
- Sand paper (fine, between 200 and 400)
- Color markers
Once you've got these things you're ready to start!
I bought 100x 5mm LED white on eBay for only $7 (including shipping).
So that's only $0,07 for each LED. You won't get colored LEDs this bright for that price!
Green is 39% of white,
Red is 36% of white,
Blue is 25% of white.
That is why the green color seems the brightest.
These are very hard to find here... (for some reason, I don't know why :P)
especially the diffused LED.
and i thought LED lighting can't be different (until now that is).
one question.. using sand paper on LED, will it reduces its quality?
cause i keep having mine get burned or its brightness reduced after a few days on normal condition.
thanks, sorry for bad english.
thumbup!
try using resistors always!!!.....normaly i use 220 ohm on each led, no matter the number of leds....maybe u already knew that but still
and that's a big help, thank you.
in that case, i'll work on my upcoming projects with resistors.
thanks again.
Simple red, green, and blue leds can be had easily for a dime a piece:
Green 5mm 100 pack 9 bucks shipping includes 100 resistors
Assorted 5mm 100 pack same deal
Orange ...8.50
Infrared 7
Red 8.50
White ...7 dollars same deal, slightly cheaper
How much are those markers and hours of your time worth sanding and colouring individual leds at 2 cents difference each...I'm sure I could find cheaper; but its just ironic to create one colour, fluoresc to multiple colours in the spectrum, then filter out the unwanted colours to get just one colour :D
I have to point some things to your story.
The white ones I bought on eBay where the cheapest for it's kind. The brightness of the White LEDs are 20.000 mcd (100x for $7). Some of the colors you've linked are only 4000mcd. That's a big difference.
Of course when I colored them there was a slightly decrease of mcd, but still way over 4000.
Also you can not take the price of the markers into the total price of making a colored LED.
It's not like I color 10 LEDs and throw the markers away :)
I can probably color thousends of LEDs with a marker and still use it for tons of other stuff.
The ones I used are almost 10years old and still work great.
Anyway, just see this instructable as an easy way to make some colored LEDs when you don't have any around. :)
As for brightness, the human eye after a certain threshold can't tell the difference in brightness - its a logarithmic sensitivity relationship...A lot of the numbers are perceived brightness - and a white led putting out 20 apparent wavelengths will appear brighter, naturally :D I would go so far as to say that 4cd red would look at bright as 20cd white, because they are comparing apples and oranges.
great instructable, ive got a soldering iron, and nothing to solder, i might find soemthing cool to do with loads of coloured LEDs =)
