3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own eBq BBQ Grill out of an Altoids box
For those of you who know me you know that I am just fascinated by building things inside of an altoids tin, but this tiny BBQ dubbed the eBq takes the cake. This tiny little BBQ that you can use to cook up your breakfast sausage features:
Built in Striker
Removable Grill
Utensil Holder
Equipment Holder
Just remember to let it cool off before you put it back into your pocket or else you will feel a nasty burn in your pants
To use the grill, open the lid and take out the grill. If you notice anything about the grill, you will see dice welded onto it. The dice will be branded onto your food whether it is vegetables, or meat. When the grill is removed, take a cube of charcoal and crumble it in. Make sure not to make a mess when putting the charcoal in. Put the grill back on, close the lid, then pour lighter fluid in and light it up. Start grilling on the new eBqBBQ GRILL.Wouldn't it be great if you imagined your boss coming in and say'n, "hey, i smell smoke" then you sayin, "oh don't worry about it, its just me bbq'n in my office!"
Step 1Materials:
Materials:
What you will need:
1 Altoids tin case with a lid that has no embrossings, or engraved text. It should be flat.
1 Xacto knife
1 coat hanger
1 pair of needle nose pliers
1 pair of regular flat head pliers
sand paper ranging from 100 grit to 2000 grit( for maximum style and performance)
69 comments
1-40 of 69next »
Mar 8, 2012. 4:13 PMarmydude1207 says:
cool!!!
Dec 3, 2011. 12:31 AMsynthdust says:
did i miss the step for the feet?
Sep 1, 2011. 7:27 AMMrcheese15 says:
im going to make a bbq with an ammo box :D
Nov 23, 2011. 2:46 PMPerfectPantaloons says:
That is genius! Like one of the .50 cal ammo boxes that you can pick up at an army navy store?
Nov 24, 2011. 4:11 PMMrcheese15 says:
yeah i was thinking something like that
Nov 25, 2011. 7:23 AMPerfectPantaloons says:
BRILLIANT!!
Sep 1, 2011. 7:25 AMMrcheese15 says:
i have to try using a jigsaw on a really low speed :/
Aug 27, 2011. 8:26 AMdrabinowitz says:
Why does the cover need to be flat?
Jun 26, 2009. 3:59 PMsilentsnip94 says:
wait whats the coiled thing inside?
Jun 26, 2009. 8:39 PMsilentsnip94 says:
oh i see it acts as a heat conducting booster lol
Aug 18, 2011. 9:49 AMfogman103 says:
you might want to add the coil to your parts list and explain what it does and where it goes.
Aug 17, 2011. 4:49 PMfogman103 says:
where did you get the dice thing?
Dec 3, 2009. 8:21 PMTgwizman says:
The electrical idea is a good one, but you wouldn't get the great smell of a good old fashion grill!
I have an Idea for a solar panel altoids can. it would go around with you and everything. it would be usb 2.0 compatable. you could set it on your dashboard on your way to work and everything else.....
One question...  How would I go about doing this?
Aug 17, 2011. 4:47 PMfogman103 says:
check out the instructable for "mighty mintyboost"
Aug 13, 2009. 4:19 PMKane94 says:
what do you use for fuel? and i made this one http://www.instructables.com/id/Altoids_Portable_BBQ_/ and its ok i like this better because the one grill but why do you have to cut the lid why cant it be you open it up and there it is. other than that please get back to me plz.
Mar 6, 2011. 8:49 PMA flyin muffin says:
I just think that the lid would be more useful than the artistic "value" off your grill
Mar 6, 2011. 8:47 PMA flyin muffin says:
You are the Picaso of grilling.
Jul 25, 2010. 11:20 AMspcon says:
Thanks for the great Instructable! I have a huge Altoids tin (About 10 in. by 6 in.), so I think I may make a scaled up one for camping now.
Mar 6, 2011. 8:40 PMA flyin muffin says:
Where did you get it from?
Feb 3, 2011. 7:51 PMhunter4639 says:
what is the spring looking thing on the left under the grill leading to the leg
Feb 3, 2011. 7:47 PMhunter4639 says:
i used a dermal tool with a cutting disc and cut it as close as i could then used a sanding bit to make it look better
May 9, 2010. 2:30 PMcantbesaved says:
 how do you light it? matches and wood?
Oct 14, 2010. 12:05 PMm0f0 says:
Haha ya I was thinking the same thing
Oct 12, 2010. 11:49 AMpalombo5050 says:
Well, I am from Texas so I tried my hand at a smoker. Check it out. http://www.instructables.com/id/eBQ-Smoker/
Oct 7, 2010. 11:07 AMpalombo5050 says:
This is GREAT. I love it. I made one when I saw this in Instructibles. How ever, I didn't use an altoid box, I went to the grocery store to the bakeing section and found two 4 inch baking pans. I bought two and used one as base and one as lid. Made it to look like a weber. I used 2 inch 8-32 bolts for legs. It holds 1 to 2 grill coals broken into pieces. It works just like a regular grill. For the grill screen, I went to BBQ section and purchased an aluminum grill screen used for grilling veggies. All items are "Food Friendly" or "Food Safe" for those anal enough to be worried about that. Remember: It's about the ingenuity and imagination. Keep on creating.
Jun 21, 2009. 8:22 PMBeachbum790 says:
Man, I have no idea how you made this with an x-acto knife, I had to just get a hammer and beat it out, this part was insane :c
Aug 29, 2010. 3:56 PMdevonkeyes says:
ha! lol thanks for making my day.
Jun 16, 2010. 11:54 AMNaesDraw says:
I'm putting one together myself. I'm having some trouble getting the wire bent cleanly, the spacing and lengths are off. Any suggestions?
Aug 13, 2010. 1:14 AMSandmans41 says:
Try Heating It till its red hot, that should make it easier to bend, Don't Burn Yourself
Aug 18, 2010. 5:59 AMNaesDraw says:
I managed cold, but thanks anyway.
Jul 27, 2009. 9:03 PMdiythings says:
not trying to be meen but be careful when you are making this! if you get a cut from it you will need a shot if you dont treat it.
Jun 11, 2010. 1:39 PMSasquatchKid says:
Whoot go BSA Im a scout just crossed over lovin i made this
May 16, 2010. 11:03 AMmetallica8080 says:
 Should i remove the lid before cutting it?
May 9, 2010. 2:20 PMcantbesaved says:
 where do i get a non embossed altoids tin?
May 16, 2010. 10:27 AMjunits15 says:
I was in the same sintuation, i just pounded out the raised letters with a hammer, it worked semi-ok
Jul 15, 2009. 12:51 PMmason0190 says:
What about the lethal toxins (i.e. lead, cyanide, etc.) in the paint? Would you like that cooked into your food!?
May 12, 2010. 1:14 PMdungeon runner says:
I'm pretty sure we stopped putting lead in our paint sometime in the sixties. I have no idea what cyanide would be doing there at ALL. Not to mention the fact that exposing the food to the resulting smoke would probably not just magically transfer itself.
Please take the time to make sure you know what you are talking about before you comment.
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:ebqbbqmaster(Alex's youtube channel)
