3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own ferrofluid in 5 minutes
Using magnetic ink and any oil lying around your house, make a substance that's liquid when it's sitting around, but turn solid in the presence of a magnetic field
Step 1Intro
Intro
This instructable will show you how to make your own ferrofluid. A ferrofluid is a fluid with magnetic particles in it, and if the fluid is exposed to a magnetic field, all the magnetic particles will align with the field lines, and making the fluid much more dense. There's a lot of cool things you can do with this fluid. Enjoy!!!
93 comments
1-40 of 93next »
Mar 20, 2012. 9:01 AMGASSYPOOTS says:
brotip: use magnets for hardness :D
Dec 4, 2011. 4:50 PMstrmrnnr says:
Wondering if you have ever heard of this material from the tape being mixed with a paste an used as a heatsink compound. Being that it is obviously metal base it should conduct heat well.
Oct 10, 2011. 6:21 PMbusterbuster18724 says:
could you get the ink out of any pen?
Jun 23, 2011. 6:18 PMmagnadox says:
Ferro fluid has the capability of a fluid controllable by magnetism, nasa uses it in space to control fuel
Oct 3, 2011. 1:16 PMstringstretcher says:
http://berglondon.com/blog/2009/10/12/the-ghost-in-the-field/
Jun 15, 2011. 1:10 PMmacgyverfan says:
are there any practical applications for ferrofluid?
Jun 5, 2011. 4:17 PMilpug says:
my cousin and his friends worked on a ferrofluid display POng once. it didnt work right apparently.
Dec 10, 2009. 10:17 AMbits1bytes2 says:
A typical ferrofluid is about 5% magnetic solids, 10% surfactant, and 85% carrier, by volume.
- magnetic solids: come from the MICR
- surfacant : either itric acid or oleic acid (which I prefer)
- carrier: veggie oil or kerosene (which is better)
So.... for a 100ml total volume, 5ml of MICR, 10ml acid, and 85ml of kerosene.
An MSDS for this can be found at www.teachersource.com/Images/UserDir/FF310MSDS.pdf
Aug 21, 2010. 1:54 PMs4mm77 says:
Wouldn't you need more MICR since the ingredient isn't pure?
Feb 10, 2011. 7:10 PMsoroka69 says:
No, no more than 10% of the total volume
Aug 21, 2010. 1:56 PMs4mm77 says:
I must make this to feel the epic texture... Where the hell can i get MICR O_O
Feb 10, 2011. 7:09 PMsoroka69 says:
Look on eBay for MICR or magnetic ink Re-Fill
Oct 6, 2010. 3:49 PMski539 says:
honestly theres an easier way to do it, one is with acetone and tapes. both easier to get. and another way i know less about but it uses kerosene and makes it really high quality. but you dont wanna be touching it because the iron is bad for you.
Aug 21, 2010. 2:09 PMs4mm77 says:
I've found some on ebay... RICOH FT-4215 TYPE 410 DEVELOPER will do?
Aug 23, 2010. 6:13 PMCursedSeal7 says:
nope, need sem different stuff, not RICOH
Nov 9, 2010. 3:23 PMraja681 says:
can someone tellme the exact thing i need for the magnetic property
May 12, 2006. 7:20 PMflashsumner says:
it's too bad the fluid becomes jagged when magnetized. I've been wondering if it would be possible to make a relief globe of the earth and 'cover' it with some sort of fluid that could 'stick' (perhaps magnetically) to the globe, filling the depressions like the oceans on the earth. Mercury would work but is obviously impractical for safety reasons. This ferrofluid would be an option except it doesn't really act fluid-like when magnetized.
Oct 14, 2007. 10:31 AMProtocol512 says:
well it's not really supposed to become solid at all,.. it's basically supposed to remain a liquid, reactive to magnetic field. When made right, the particles, and the fluid don't separate. And when they do, it's because of a constant force. A solid state magnet only pulls one direction, constantly. When you use an electromagnet, and ferrite, the change in direction occurs so quickly, that the solids never have time to settle out of the fluid. When this occurs, you can idealy suspend the solid, and liquid, in a perm. state, without separation.
Aug 31, 2009. 6:33 PMocbarterguy says:
I was just wondering, I just bought some "Ferrofluid" on ebay, got it home, and noticed that it coated my beaker in a film as it passed over it. After doing some research, I found that you can put it in a median like alcohol, or ethenol to prevent it from sticking to the glass: But when I tried with a 50/50 alcohol solution, the mixture became foggy at the top, and there are what look like random sized filings, almost like the guy sold me really cheap stuff. I've seen several videos in which the fluid literally behaves like an individual entity, not a blob of metal stuff. Basically my question is: How do I get this stuff to behave like it is supposed to in a small glass beaker without it looking cheap and foggy? Thanks so much!! -Jay
Dec 12, 2009. 8:55 AMvon rad says:
Ferro fluid is nasty.  In spills, accidental contact, multiple field interactions - experimentation means discovery so no predictable results = "ferro fluid is nasty".  Recently I have been using glass, aluminum and wood to identify magnetic reactivity and (visually) field definition.  In air it takes a long time to "grow" the field.  The advantage over the ferro-fluid is that you can see the "grain" of the field, you can measure angular "reactions" and determine how vectors were resolved.
VR,
Mar 5, 2009. 7:38 AMtheblasto says:
Epoxy is a fantastic idea! If you mixed the MIRC with a light-weight liquid epoxy (working quick)... applied a magnet... and let it harden... you'd have a nifty little piece of permanent art! :)
Sep 30, 2009. 9:39 AMflying texan says:
what if you used grease in stead of oil, then heat it to drain excess, then the sticky grease would keep it from splitting to make it nice and smooth. another thought would be to mix the MIRC with gellotin, I wonder what that would do? how would you grind ferric oxide as fine as graphite lube.
Dec 12, 2009. 8:48 AMvon rad says:
A rock tumbler using spherical metal balls or ball mill break it down to a fine grain.
VR
May 10, 2009. 9:28 AMnickangel1 says:
You said "some oil" and "a bit of ink". Can you please tell a good ratio between how much oil and how much developer?? Thanx ANYWAY AWESOME INSTRUCTABLE.. :) you're great
Jan 16, 2009. 4:10 PMtwenglish1 says:
will this work with all toner?? cause i have an old cartridge that still has some toner in it and i was wondering if i could use that
May 1, 2009. 8:37 AMzim_256 says:
It doesn't work at all, using toner or developer (as i did), you create a ferromagnetic "suspension", not a fluid. It doesn't make the effect seen for example in snOil, when you put a magnet close to the suspension, it just magnetizes the developer particles, not the entire fluid. That effect is not visible because the particles are covered with dark oil (oil mixed with some residual toner from the developer). And it smells life french fries! (i reused old cooking oil).
Jan 29, 2009. 10:20 PMchefbrian says:
Five syllables, Mimetic Polyalloy
Feb 8, 2009. 7:07 PMchriskarr says:
Isn't 'Mimetic Polyalloy' six syllables? If I'm wrong, I'll be surprised, but if I'm right, I'll assume that somebody wasn't taking much time to think about syllable count.
Feb 9, 2009. 2:55 PMVirus1105 says:
I count 7
Mar 22, 2009. 11:01 AMAnsoiaron says:
Me too...
Feb 9, 2009. 5:34 PMchriskarr says:
Yep, you're right. Mim-et-ic- -pol-y-all-oy You were right. Seven syllables.
Mar 1, 2009. 9:41 AMboky2405 says:
10 syllables
Mar 1, 2009. 1:21 PMtwenglish1 says:
prove it
Apr 2, 2009. 6:24 PMduct tape apprentice says:
Over 9,000 syllables.
Jun 26, 2010. 3:44 PMtoogers says:
IT'S OVAR NINE THOUSAND!!!!!!1
Apr 6, 2009. 5:33 PMNexnaught says:
this is ridiculous. An argument over how many syllables a phrase has.
Jun 29, 2009. 8:40 PMGage987 says:
16 is the most syllables the words could have because, they are only 16 characters *not counting the spaces
Jun 29, 2009. 10:19 PMchriskarr says:
You, my friends, were just trolled by a duct tape apprentice.
Jan 17, 2011. 10:51 PMProject D says:
Lol pwnd
1-40 of 93next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:prank
here: http://www.artiswrong.com But really, I'm just this guy. For up-to-the-minute, action-packed updates on my life (and occasional drawings of tapeworms getting it on), check out my blog here: ht...
more »
