3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own ferrofluid in 5 minutes
Step 3Mix It!
Mix It!
Pour some oil into a mixing cup. Add a bit of the ink, and stir it into the oil. You're making a suspension, so the ink won't dissolve in the oil. Just stir it. Keep on adding ink and stirring until you have a thick solution. There's no exact science to this. A good guideline for identifying a well-mixed fluid is that if you tip your mixing cup, the fluid should ooze rather than slosh.
3 comments
Dec 10, 2009. 10:17 AMbits1bytes2 says:
A typical ferrofluid is about 5% magnetic solids, 10% surfactant, and 85% carrier, by volume.
- magnetic solids: come from the MICR
- surfacant : either itric acid or oleic acid (which I prefer)
- carrier: veggie oil or kerosene (which is better)
So.... for a 100ml total volume, 5ml of MICR, 10ml acid, and 85ml of kerosene.
An MSDS for this can be found at www.teachersource.com/Images/UserDir/FF310MSDS.pdf
Aug 21, 2010. 1:54 PMs4mm77 says:
Wouldn't you need more MICR since the ingredient isn't pure?
Feb 10, 2011. 7:10 PMsoroka69 says:
No, no more than 10% of the total volume
May 10, 2009. 9:28 AMnickangel1 says:
You said "some oil" and "a bit of ink". Can you please tell a good ratio between how much oil and how much developer?? Thanx ANYWAY AWESOME INSTRUCTABLE.. :) you're great
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:prank
here: http://www.artiswrong.com But really, I'm just this guy. For up-to-the-minute, action-packed updates on my life (and occasional drawings of tapeworms getting it on), check out my blog here: ht...
more »
