A big company named Alcoa makes "Reynolds Freezer Paper" and because I hate big companies, I'm gonna show you today how to make your own freezer paper. We shall call it "Makepiesnotsense Sticky Paper".
Step 1: Materials & Tools.
1) sheet of airmail paper
2) thin plastic bag
*Alternatively use
1) sheet of standard white paper
2) standard black garbage bag
See Majjuss Sticky Paper or skip to Step 6.
Tools:
3) iron
4) scissors
Tools you'll need if you use the paper as stencil:
5) cutter knife
6) pencil
So, children, if you try this at home, just remember:
If you want your result to be radiant,
be gentle, be careful and patient.
Step 2: Design & Caption.
Of course you can print it with an actual computer printer if you haven't run out of ink like me. But be sure to lightly tape it onto some thicker paper, since printers have an aversion to thin airmail paper. You can choose an image with islands, it's no longer a problem with Makepiesnotsense Sticky Paper!
Here's a tip: Even without printer you can use your word processing software to generate a caption for your image. Write whatever you wanna write and just copy it.
Step 3: Paper & Plastic.
Step 4: Ironing.
When you iron the paper onto the plastic, the plastic will shrink and then burn onto the paper and then shrink again. This means your paper will get a bit crumpled, but the good thing is it will get all even again if you iron it onto the piece of clothing.
Step 5: Cutting.
I use acrylic paint for my prints and let them dry over night before removing the stencil.
Step 6: Majjuss Sticky Paper
The previous steps apply to both methods.
After you've fused paper and plastic with the iron and cut off excess plastic, check your garbage bag side. Small holes (diameter <= 1 millimeter) will not noticeably affect the outcome of your print. If you see any bigger holes, you can cut out another piece of plastic, lay it over the holes and iron on again. Then you go about it the same way as with the other material: cut out the stencil with an x-acto knife and iron it onto your fabric. For more information, read comments or feel free to ask.
Visit Our Store »
Go Pro Today »
alas, I have not heard of inklingo. The technique I have presented here serves the purpose of creating a stencil, so that printing is possible, if you apply (acrylic or fabric) paint on the shirt+stencil. You will need inkjet transfer paper (in case you have an inkjet and not a laser printer) if you want to iron a print directly onto the shirt. It is available in stores and over the internet. Good luck with your printing projects + greetings,
makepiesnotsene
can you get your hand on garbage bags? That's the type of plastic you will need in order to get it fused with printer paper... The garbage bags I mean are ususally black or blue and thicker than standard grocery bags.
Good luck!
makepiesnotsense
yes, you summed it up correctly. except, in between the last two steps, you forgot to mention the act of painting your ornament/picture onto the shirt. i'm sure you're well aware of it though. greetings!
I tried it with plastic wrap. Let me tell you that it was a messy business and that it didn't work out at all. So, stick to the plastic bags. It always depends though, there are all kinds of plastic bags out there in the world. You will have to find out, which paper will fuse with what kind of plastic sheet the best.
Best regards,
makepiesnotsense
1. cut the design into the freezer paper,
2. iron it onto the shirt and
3. apply paint directly on shirt.
cheers!
I've been using your "sticky paper" method for a good year or more now, and it's been fantastic. I've had comments on how professional my shirts look, and I love them. Your tutorial made everything easy, as I had never heard of Freezer Paper before, so I don't think it is sold here.
So, thanks for helping me make great shirts!
This works amazingly great! I was a bit hesitant to try this at first because of the whole ironing plastic onto fabric thing, but you're right! It does become one with the paper and peels off easily!
Thanks again!
e.g. http://www.youtube.com/watch?v=D7vWTTfCFJ4
get yourself those 'iron on' sheets for a printer and follow their instructions, if using tools and investing work and time seems like a bad alternative. it will save you a headache.
good luck,
makepiesnotsense
(Please don't mind the excess of questions, I just love to..know stuff)
-PKT
