loading
Step 2: Water resistant glue
This glue can be used for glass, ceramics, porcelain or metal. It worked beautifully when I made coasters by gluing cork (left over from the floor) to sample porcelain tiles, and for gluing aluminum foil to cardboard for a Halloween costume -- this glue can adhere to non porous materials, unlike the flour paste in the previous step. I also tried repairing a broken mug with it but it fell apart when I filled it with hot tea -- this glue is somewhat waterproof, but not heat resistant. You can fix a plate with it, but do not put that plate in the dishwasher or microwave.
Ingredients:
1 pack unflavored gelatin
3 1/2 tsp water
2 tsp skim milk
In a small cup pour gelatin over cold water to soften.
Boil milk (a few seconds in the microwave will do the trick) then mix it into the wet gelatin and stir till all the lumps have dissolved.
Adhesion works best when this is applied hot. If it is too runny for the surface you are gluing, let it to cool down and gel before you paint it on.
Store in a small covered jar for a few days. Warm over a pan of hot water before use.
<p>going to make it on weekend</p>
Can you use self rising flour?
<p>If that's all you've got you can try using it. The extra baking soda won't increase adherence properties, but I don't think there's enough of it to be detrimental either.</p>
<p>WHAT DOES THE SUGAR DO?</p>
<p>(Shhhh... not so loud....)</p><p>The sugar increases the adherence properties... Haven't you noticed how sticky a table is after you've spilled some soda on it and it's dried out?</p>
I appologize in my comment i meant to type &quot;vitamin e&quot;.
<p>Also annoying how when you reply to yourself, your comment shows up twice...</p>
<p>I would have given you a thumb-up ,but I don't think they offer that option. </p>
Can you substitute something else for the alum, like salt, or naybe use honey or b itamin e oil as a preservative?
<p>You'd have to add a lot of salt for it to work as a preservative, so it would probably interfere with the adhesive properties. I don't think vitamin E would help: it helps oils from going rancid, I don't think it has much effect on purely water based solutions. Maybe you could use a preservative for cosmetics, like <a>Germall Plus</a>. I'm sure there are other alternatives out there, I just haven't tried them. You might try experimenting with a ton of sugar... (think jam: sugar is what preserves the fruit). And sugar is sticky.</p>
<p>That link didn't work... but you can google it and find it easily enough.</p>
<p>Yes, isn't it annoying how you can't edit your comments after you post them?</p>
We are working on making our own all natural shoes with earthing and a like-barefoot design in mind. Leather moccasins with rawhide soles we think will work great for moat days, and everything is sewn in that design, but they are not water resistant.<br><br>We are considering felted wool boots, possibly with a cork sole, for wet days. Does anyone know or have advice on if this water resistant glue may hold up for shoes, or if it would stick felted wool to cork well? I expect it to wear out and need fixing, but hopefully be able to get at least a couple months of regular use before needing to fix them.
<p>Natural material needs constant care. Decent water resistance can be gotten with oil, soft wax or grease applied to (soaked into) leather. Seams have to be tight and the leather needs re-application.</p>
I would hesitate to use this for shoes... not only does the glue for shoes need to be super strong and durable, it has to be waterproof AND flexible... that's a pretty tall order. Of course I do encourage you to experiment (and share your results too!) but I wouldn't sell anything made with this without extensive testing first.
<p>Hello , how can I make water proof glue with 15% solid content and 85% water . please help. </p>
<p>Worked well. I see myself making this glue many times in the future.</p>
<p>does it work on cardboard</p>
<p>Can this be made with white flour?</p>
<p>Yes! All purpose white flour, or, if you happen to have it, bread making flour is even better.</p>
<p>this was used and still is for wall paper paste.</p>
<p>I just made your milk glue recipe. The 1-1/2 Tbsp of water was literally a drop in a bucket. I had to add a LOT of water, just to get it to the consistency of pancake batter. I'm afraid if I add enough to make it as thin as commercially available white glue, it will make it too thin to work. I just tested it on two sheets of paper. I'll report back tomorrow.</p>
<p>The paper test seemed to work well. Just a little 'wavy' since the paper got soaked pretty good. Moving on to two pieces of wood (which is why I wanted to make this). Stay tuned.</p>
<p>I am pleasantly surprised by how well it glued two pieces of wood together. The bond seems pretty strong, although I did not try to test it to failure.</p><p>And again, the mixture can out more like paste than white glue. I have the batch in a zip-lock bag, and it tends to firm up into a stiff gel. After a few minutes of kneading it while in the bag, it becomes more pliable.</p><p>To apply it, I just dipped my finger in the bag o' glue, and smeared some on the work piece.</p><p>My reason for trying this recipe was to create a 100% natural wood glue for biodegradable caskets, coffins and urns, and I pretty happy with it. I think I'll leave it in gel form, and not try to thin it out any more.</p>
<p>Wow! For that use, frankly, I'd be careful (and I definitely would not thin it out any more)... you wouldn't want it to fail at the wrong moment... But as long as you have very good woodworking skills, and you clamp the pieces really well when gluing, and you add pegs or those little wooden wafers to reinforce and hold the joints then it should be good. If the glue is just sealing and steadying a joint which would otherwise hold together mechanically then there's be no reason to worry. You should check out Henley's book though, the recipes here are just the tip of the iceberg, there are LOTS of other glue recipes, some of which might be better for woodworking.</p>
<p>Glue is definitely just the suspenders for a 'belt and suspenders' design. I am actually writing a book on do-it-yourself caskets and coffins. For traditional (modern) caskets, the design calls for modern glue with fancy metal ornaments, hinges, catches, etc. I am also including a design for the new trend in 'green' burials. According to the Green Burial Council, all adhesives must be 100% natural. Because the guidelines for green burials are very similar to Jewish burials, the coffin design is the same for both. The HUGH difference is in the glue. Green says 100% natural, Jewish says no metal (nails and screws) and animal products, so now its time to experiment with wheat paste recipes. </p>
<p>You can probably use agar in place of gelatin, from sea weed. Veggie gelaton</p>
<p>Had the book ofr years, great for making things.</p>
<p>I've tried this and it works really really well </p>
<p>I just finished making the wheat paste (flour and water) version. After mixing, the batch is VERY runny, but while cooking, it quickly thickened to the consistency of cake frosting. It never turned clear, but it is slightly translucent. It is cooling in a jar right now, I'll try a couple gluing experiments after its cool.</p>
<p>Intuitively I doubt this will be any good at gluing wood, but I'm looking forward to hearing about the results... Thanks for testing and sharing!</p>
<p>Okay, glued to blocks of wood together, and let it sit overnight. It is amazingly strong. My guess is because one of the pieces of wood is about 3 square inches on the side I glued, and I glued the entire surface. </p><p>So the tests confirmed that both the milk glue and flour glue will work well for a backup to mechanical joining techniques.</p>
<p>I used to have a book from the same era called &quot;Fortunes in Formulas&quot; I have no idea where it went but, it was as the title said. It had similar things in it as this book. what a great find.</p>
<p>There is a copy of the book you mentioned on archive.org - scans of the original edition from the start of the 20th century in all kinds of ebook formats and as a pdf.</p>
<p>Yes, in fact in my description above I give a link. Text from step 5 copied here: &quot;Henley's is now in the public domain and a PDF file is available for free <a href="http://www.archive.org/details/henleystwentieth00hiscrich" rel="nofollow">here</a>, but after trying to read off the screen for a couple hours I decided I wanted a hard copy.&quot;</p>
<p>Autsch, my bad </p>
<p>No worries!</p>
In india we make it on Uttarayan (Kite flying Festival) to stick kites we call it lahe I make it myself in small vesal almost 1 cup for me &amp; my friends in my childhood thanks to remember me to those Golden age.
<p>do u have to use the alum powder and can u use regular flower</p>
<p>The alum powder is optional, you can just leave it out if you don't have any.</p>
<p>Belsey, this was amusing and helpful. And I love old books of formulae, too - leather conditioners, waterproofing for canvas, solutions to clean up fossil and mineral specimans, inks for pens made of feather shafts or bamboo, plaster for sculpting, determining the number of gallons of water required to fill the fish pond one has just dug and so on, so thank you for the Henley book. Now, if only you could give me a magic recipe for instant. delicious, Swiss RACLETTE,(w/potatoes &amp; cornichon), I could die a happy old woman. Chubbier than pre-raclette, but happier by far.</p>
<p>Just saw this now... and I can definitely help you with the raclette... because all you need is a big hunk of cheese and an open fire with a few rocks to prop up the cheese. Although I must say the little electric heater I have, though less &quot;authentic&quot; is much more convenient... Thanks for reminding me of this! Now I know what I'm having for dinner tonight...</p>
<p>Nice instructable. Good job of showing it all to us with very good photography (are you a professional photographer?). I've been looking for some complete glue recipes and this is it. Thanks.</p>
<p>Sorry for the reply delay -- didn't see you comment till now. Thanks, and hope you enjoyed making the glue! I'm not a professional photographer (in fact all these photos are just taken with my cell phone!) but I am a professional designer. You can see some of my work here: http://www.makepopupcards.com.</p>
<p>Hi, Would this glue be good for putting wallpaper on a cardboard house??</p>
<p>Yes, the paste would work very well for that application. The water resistant one would work too.</p>
About This Instructable
293,305views
261favorites
License:
Bio: I am a paper engineer, writer, maker and chemist wannabe. In addition to pop-up cards I design and build furniture, lights, costumes or whatever I ... More »
More by belsey:Rainbow Pussy Hat Duck Tape Woven Heart Beach Bag Scandinavian woven heart basket
Add instructable to:
