3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own gravel vacuum for your Aquarium
A very handy piece of aquarium equipment is a gravel vac. They are useful for getting debris out of the gravel at the bottom of your tank. But they can be expensive, so I'm going to show you how to make a gravel vac for a very little sum!
What you will need:
-Some plastic tubing, not to long, about a metre or so.
-A Coca-Cola bottle or something like it.
Step 1Get some plastic tubing
Get some plastic tubing. My local aquarium shop had some that I presume was for filters. He gave me some for free. It needs to be about a metre long, or about 3 feet.
8 comments
Sep 20, 2011. 8:33 PMlalexander says:
if you use tubing that is slightly larger than the inside diameter of the neck of the bottle, you can cut the tube at an extreme angle, and stick the tip thru and thenpull it thru with plyers to make a very tight fit. this will do away with the cap all together.
Jun 15, 2011. 6:09 AMsandar says:
since you already put the entire hose into the tank, it's enough to close one end of the hose with your finger (or just squeeze the hose) and once the hose is over the bucket just let go
Sep 5, 2009. 9:05 PMdom13marco says:
Thank you! I saved quite a bit of money using this.
Sep 1, 2009. 3:05 AMll0ll says:
nice instructable, simple and effective :) saves needed to buy one One tip though: Rather than sucking, which inevitably results in drinking the water(!!), place the entire tube and bottle into the water until it fills up, then once it has, place your thump over the tube end (still underwater), and then take out that end, place it over your bucket, and remove your thump.
Jul 25, 2009. 9:57 AMJ@50n says:
my guppies make an awful mess that smells after a week or so, how often would you remccomend using this? and you should post a video of you using it. also another question, does this take a lot of water from the tank or just a little ammount? Thanks
Jul 29, 2009. 9:15 AMJ@50n says:
ok that answers my question, thanks Sam!
Jul 5, 2009. 9:21 AMBartboy says:
Cool! If you had a log enough hose, you could put the end outside! Or use the bottle as a funnel to fill the aquarium after!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Sam McCauley
