3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own keyboard with integrated trackball mouse
My home computer setup is much like a media center PC. I have a small Shuttle PC hooked up to a large 37" 1080p LCD panel as the main monitor. As a bachelor renting a house with friends, my PC is in the same room as my bed, and there are a lot of times when I'm watching a DVD or Hulu.com or playing World of Warcraft and would really like to be able to lounge on the bed and control the computer.
I have used wireless keyboard & mouse combo units and found that they are totally unreliable. The thumb stick is nearly useless in precision and doesn't allow you to quickly move the mouse around the screen. They also tend to run through batteries quickly, and when running low on batteries they will miss key presses or mouse input randomly. I searched for a wired keyboard & mouse combo and found that my options were very limited. Many of them were built for media center PCs and have non-standard keyboard layouts, small keys, and were also pretty expensive.
After running out of other options, I decided to roll my own! This instructable will show you how to take an ordinary USB keyboard and USB trackball mouse and combine them into a single unit. The units in this instructable are WIRED, however you should be able to do the same thing with a wireless keyboard and mouse, albeit at a much higher price.
Step 1Gather the materials...
I purchased all of the electronic items in this instructable at Newegg.com. Here is the list:
1) LITE-ON Black USB keyboard - $7
2) Logitech Gray 3 Buttons + Wheel USB TrackBall TrackMan Wheel Mouse - $30
3) SYBA 4-port mini USB hub - $8
4) BYTECC 10ft USB extension cable (Type-A Male-Female) - $3
5) JB Weld - Had this already.. use whatever epoxy-like compound you have handy
6) Small Zip Ties - Already had this as well, feel free to use twist ties or whatever
Total price: $48 + shipping
Total time spent: ~30 minutes construction time, plus a few hours to let the JB weld set properly
38 comments
May 30, 2010. 6:00 AMNikunj Rastogi says:
 i does not understand ur step no 3 clearly, plese or clera kare
May 21, 2010. 10:00 AMKAoC says:
You sir quiet obviously do not do enough math with your computer. YOU DESTROYED YOUR PRECIOUS NUMPAD!!! Oh god I couldn't ever think of doing such an atrocious act. How will you ever efficiently enter data? :( I pity you, sir.
Jan 31, 2009. 4:34 AMcarov says:
(removed by author or community request)
Apr 5, 2010. 10:10 AMTreknology says:
Carov, I think your comment sux. Criticism should be constructive and/or encouraging.
CyberBill: Rather than sacrifice the numeric pad, I would get a piece of 3mm acrylic cut to size so that it fits under the keyboard and protrudes far enough on the right side so you can attach the track-ball.
If the keyboard cable is coiled, thread the trackball cable through the middle. If not, rather than twisting them together, use braiding technique--that way they still look twisted together, but they won't keep trying to untwist.
Apr 8, 2010. 7:37 AMSaturn V says:
Agreed
May 20, 2010. 12:09 PMbluegillfly says:
Not so fast, CB :-)
The tape we all know and love was originally called duck tape, and there is even a brand of it called Duck Tape, most likely available at any home improvement store near you, at least if you live in the United States.
It only came to be called duct tape later (= after WW II; it was developed during the war to fill the need for a strong, waterproof tape).  Also, if you look on rolls of duct tape, they typically include a warning not to use it on heating and air conditioning ducts. Why not? It's waterproof, but heatproof? Not so much. Some kind of metallized tape is usually used on ducts,.
Apr 8, 2010. 7:41 AMSaturn V says:
Actually, its original use was to tape up ammunition crates in WWII and make them waterproof.  Then it was called Duct Tape, because it was the only tape in that time period that could create a strong enough seal, and last for a long time.
Feb 11, 2010. 11:45 AMdeathsmileyinc says:
it still doesn't look nice :( it isn't hard to build the cabling into the keyboards.
its hard to paint the keyboard but you could have painted the trackball casing black and use some Plexiglas or anything to smooth out the edges between the trackball and the keyboard.
Dec 9, 2009. 7:03 PMfoxtrot4697 says:
duck tape is always the best way to go
Dec 5, 2009. 9:32 PMuberben says:
 Actually, it was originally created to water proof ammo cases in world war 2 and so was named duck tape. The name was later changed to duct tape. en.wikipedia.org/wiki/Duct_tape
Jul 23, 2009. 12:02 AMrocketman217 says:
i think it might of been a joke...............................................just maybe
Jun 22, 2009. 7:34 AMA.C.E. says:
well yeah, but on some rolls of duct tape, presumably made by a different company, there is a duck on the inside. i would really do this, but i like my keypad. i might do it anyway, but use some bondo or something to make the mouse look more ""integrated"" or something.. but i like it : ) if i get a good looking one and send you a pic, can i collaborate to make it look better?
Feb 2, 2010. 1:15 AMLance Mt. says:
You sir would make one cruel admin, I tremble in fear, or maybe thats urine. Hmm.
Apr 14, 2009. 8:04 AMvenomireland says:
I think that actually would look better, this is awful, why destroy the Number pad?
Oct 7, 2009. 6:54 PMpancho del rancho says:
you should try it on the wii see if the mouse works
Jul 1, 2009. 10:23 PMerikals says:
i'll be giving this a go as soon as I get an old keyboard (PS/2) and a trackball mouse... Thanks for publishing this great Instructable Keep it up.
Jul 13, 2009. 12:22 PMerikos kostarikos says:
your name looks like mine:P
Jun 29, 2009. 8:38 PMmemyselfand1 says:
hmmm...... so effectively, you've just stuck a mouse on the keyboard and plugged them both into a hub connected to the computer. Pointless and a slight waste of a mouse, but if it works I shouldn't be criticizing it.
Nov 24, 2008. 2:48 AMKarel Jansens says:
Not that I'm promoting Brando or anything (they do sell some amazingly bad crap), but as you indicated your cost is USD 48 + shipping, I'd invite you to take a look at this:
http://usb.brando.com.hk/prod_detail.php?prod_id=00678
And it's wireless too!
Jun 22, 2009. 7:37 AMA.C.E. says:
and as for the whole laptop keyboard thing, i got a laptop with a complete keyboard that has no curve or anything to mess it up. i was thinking the same thing while trying to pick out a laptop.
Nov 24, 2008. 9:25 AMKarel Jansens says:
I have an Accuratus ToughballAccuratus Toughball myself. It has a pretty standard UK QWERTY layout, but it came out a lot more expensive than this Brando thingie (which hopefully doesn't try to match Brando's general level of quality). Added bonuses of the Accuratus are a scroll wheel and left button on both sides of the keyboard. Also, it holds surprisingly comfortably.
I've been looking at the Brando because I'm planning to kit out a house with "Beagleboard-powered" TVs (and central NAS media storage). For mediacenters the Brando should indeed be more than enough. The media buttons are unlikely to work in Linux, but that's hardly a problem with VLC Media Player.
Nov 24, 2008. 11:13 AMKarel Jansens says:
Pretty much the same as bluetooth: around ten meters (30 ft?) without obstacles. Let's just call it mighty fine couch potatoe material. :)
Nov 24, 2008. 6:19 AMJakeTobak says:
Thanks for the link, I think I might grab one of those for someone's Christmas present :P
Apr 13, 2009. 8:36 PMPhvxoui says:
dude with all respect thats some Ghetto A$$ Sh!T!!! Awesome!!! lol i had a 2.5 hdd enclouser crammed on a 3.5 sata drive and a 2nd comp power supply jump started and hooked to the hdd for power cause the USB wasnt enough now thats Ghetto man! lol A+++
Mar 30, 2009. 1:18 PMMairseyDotes says:
Hmmm. Instead of destroying the number pad, get a piece of Luan door skin and cut it to fit under the keyboard, with a few inches projecting to the side (the right side if you are not a Southpaw). Paint it to match the keyboard. Wit for the paint to dry. Hot-glue it to the bottom of the keyboard. Hot-glue the trackball to the top of the Luan, whichever side you put it on. Hot-glue the USB hub under the keyboard, plug in keyboard and trackball, and bundle the excess wires under the keyboard.
Mar 14, 2009. 7:56 AMlupinesoul says:
Can this even be considered an instructable? This is not as informative as "How to Escape from America".
Jan 30, 2009. 11:44 PMYerboogieman says:
One of my friends that works for microsoft designing keyboards and mice, he made a Really nice keyboard and mouse, the keyboard and mouse dock at the same space, the keyboard has a tiny touchpad for when your mouse dies, and for little things.
Nov 24, 2008. 4:08 AMPKM says:
If you want to be super-l33t you could desolder the button switches and glue them to the left side of your keyboard. I have seen a wireless keyboard/trackball with that layout, that you hold like a Game Gear (if you're old enough to remember what one of those is :P) and control the mouse with your thumbs.
Nov 24, 2008. 3:20 PMPadlock says:
A keyboard doesn't have button switches... It has two layers embedded in a clear plastic sheet with conductive traces on them, separated by a thin, plastic sheet in between.
Nov 25, 2008. 5:36 AMPKM says:
I meant the switches for the mouse buttons, so you could use the mouse in the "game gear grip". In retrospect I'm not sure that would add much to the design, though, I just saw it on a friend's wireless keyboard and thought it was cool. It appeals to the original-Gameboy-and-similar-handheld-playing part of me that grew up with the "movement with one thumb, actions with the other" instinct.
Nov 26, 2008. 8:04 PMPadlock says:
Oh, ok. Yah, that would make it easier. More classy, too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:CyberBill
