Step 5Making the LED string
1) Strip both wires fully, so there's no insulation left.
2) Start with one stripped wire, and attach the positive side of the LED to the top of the wire as a base. You can identify the positive side by seeing which of the two metal legs is longer -- the longer leg is the positive side. See pictures for clarification.
3) Continue down the wire, attaching LEDs by their positive side to the stripped wire. Each subsequent LED should sit about where its neighbor's tail ends.
4) After desired length is reached, do the same thing with the negative side so it looks like the
following:
5) Use pliers as necessary to crimp the ends onto the wire.
6) If there's a single short circuits, the blade won't light! (!!!!!!!!)
Make sure there are no short circuits between the long wires. A short will happen if the positive wire touches the negative wire -- so if the two wires ever cross-over and touch, there will be a short circuit and the blade won't light.
7) If you made a crossbar/tip for the string of LEDS, attach the top of the string to it. Lower the string through the blade, and attach the bottom. Adding a reflective bottom helps the light stay inside the
blade as well.
http://www.save-on-crafts.com/neon.html?gclid=CLyKvueiqpYCFQ4RnQodM15jyw
http://www.elbestbuy.com/?gclid=CIW24viiqpYCFQGbnAoda1RUxw
http://www.thatscoolwire.com/?gclid=COzfjv6iqpYCFQpknAodr0uezA
