Make your own lightsaber!
Step 7Try it out! See if it works!
There are all kinds of variations on the construction method that are possible. This is one possible way of doing it (as with anything!)
If nothing lights, check the LED string for shorts. That's the most likely problem.
If the motor shaft is touching anything, it won't work.
Have fun with it! Tell me if you make a lightsaber!
10 comments
Dec 18, 2009. 3:31 AMdevinda says:
where can we buy clear polycarbonite tubes, exept for the site http//:polyzone.com
Dec 18, 2009. 9:57 PMblackchurch says:
Sep 3, 2010. 1:11 AMdevinda says:
I'm frm sri lanka. And my parents really don not like internet shopping for some reason. I did make a light saber and it did turn out really good. I got this transparent tube from a shop called shanti plastics in mountlavania and use sand paper on it.
Sep 9, 2010. 6:37 AMdevinda says:
srry my brother broke it. As i told i took a plastic clear tube,( it was around 2m long so i cut it) from shathi plastics. Check out http://www.shanthiplastic.com/. They i scarped it with sand paper. Then i took a pvc tube, cut it to the lenght i needed and i covered it in blue tape (also frm shanthi plastic) . then did the circuit and stuff and it works
Mar 31, 2010. 9:42 AMfloryzzz says:
 Nice work but one tip try at de inside of the cleatube some  paper it defuses the licht
Nov 11, 2009. 5:52 PMsparky12345 says:
sweet!
Sep 19, 2009. 9:34 PMCoJoTheManH0 says:
The blades look amazing
Jul 13, 2009. 8:55 PMspn_phoenix_92 says:
Where can u buy those clear polycarbonite tubes for the blades? & for how much?
Jul 29, 2009. 10:39 AMbuddha_123 says:
you can buy polycarbonate tube at this website i found
http//:polyzone.com
how much it costs depends on the length you get it
Jul 2, 2009. 11:42 AMYashknowsbetter says:
Yes..glue diffusion is the best technique to avoid the spots..courtesy " awesome led cube"..great ible though..i'll try and make it tomorrow! thanks!
Jul 3, 2009. 8:52 AMYashknowsbetter says:
sure..it had slipped my mind today...but tomorrow, i promise you a trip to the local hardware shop. and im gonna make it! i'll stay in touch via mail now!
May 3, 2009. 10:34 AMBigPaws says:
COOL!!!
Oct 23, 2008. 5:28 PMSableIsland says:
You could get those bright spots out by covering the LEDs in Hot Glue. It defuses the light quite a bit.
Idea from
http://www.instructables.com/id/Awesome-led-cube
Oct 22, 2008. 3:50 PMthecrow117 says:
why are some spots brigter yhen others
Oct 23, 2008. 3:03 PMsoapdude says:
The spots that are brighter are where the LEDS are located in the tube.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:nagle
It's me, Prince Nagle Nagle!
