3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Functional USB Flash Drive Rubiks Cube
Step 6Assemble the pieces
Assemble the pieces
If everything fits you need to apply them in the following way:
Put the screw through the hole of the washer and glue the usb flash drive on top of it. Take good care, that the screw is still able to turn smoothly. As you can see in the picture, I applied an extra layer of Apoxie® Sculpt on the back left side to have a better result in sliding it up.
Now glue the screw to the inside of the hole of part 2. Make sure, that the usb flash drive is turnable.
Put your finished product back into the lip balm stick and then into the edge piece. Apply the bottom part and make sure, that there is no hole between the pieces. If there is, take the stick back out and use a box cutter to shorten the top of the stick (graining didn't work out to well for me).
Paint the part off the stick that might shine through with a black permanent marker and use the Felt Polishing Wheel from your Dremel to get rid of the extra paint.
Reassemble all the pieces and make sure, that your are able to smoothly turn the stick up and down. Now fix the side of the edge piece, as shown in the picture with the modelling clay.
Glue the part I marked with orange in the picture to the bottom of the corner piece (while the stick is turned all the way up).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
176
Author:BrittLiv
I'm a Chemical and Biological Engineering student especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
