Step 2Measure and cut first layer
I used a rotary cutter to cut the laminate. This is not necessary, but it was handy. If you don't have a rotary cutter, mark the lines with permanent marker on sheet and cut carefully with scissors.
Set on top to double check that you have approx 1/4" space to edge.
This layer will allow you to take off your design at a later time- therefore it is intended to be non permanent. I do not know what will happen if modpodge is applied directly to a laptop, nor did I want to find out. I bear no responsibility to any damage incurred to your machine should you choose to go this route.
Add Comment
