Make your own oriental looking bracelet
This bracelet is made of simple materials and looks great.
What you'll need:
-iron wire
-pliers
-cylindric objects of various sizes
-a coin (or a fingerhat)
-beads
-glue
Before starting, be aware of the fact that iron wire has sharp ends, and you will probably cut yourself a few times.
Step 1Start shaping
Start shaping
Start by cutting off a piece of iron wire of about 40 cm long. Take one end of it and put it between a pencil and a coin, holding it together with your thumb. Thanks to the coin, you can put pressure on the iron wire without hurting your finger.
With your other hand, turn the iron wire tightly around the pencil. Make one full turn.
You now have a little curl at the end of the wire, only the very end of it is still straight. You need to cut that straight bit off (just a cm).
6 comments
May 4, 2009. 3:46 PMdobbylvr says:
Awesomeful!!!!!! Love it!!!!!!!!!!!!!!!!
May 3, 2009. 1:54 PMlemonie says:
This looks great. Can you be more specific about the wire (exactly what is is where did you get it?) L
May 4, 2009. 8:26 AMlemonie says:
Looks like it might be plated with something (I'm only thinking about corrosion & allergic reaction) - I guess this hasn't given you any trouble? L
May 4, 2009. 9:20 AMlemonie says:
Ah, thanks - you ever had one of those alloy-watches that are (something) plated on top of copper? When they corrode they go really nasty... I think zinc is OK mainly. L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:judith_ou
