Step 7Fuse the layers together
Carefully cover the main area of the project with two pieces of foil that match the size of the first two.
You will want the edges to remain unfused so we can join the two sides by fusing later.
Alright lets take that low heat iron and starting at one end move the iron over the foil in a pattern that applies heat to all areas you have the foil over.
As the plastic cools it will shrink a little. the shrinkage will cause bunching but you can fight the bunching by applying pressure with your flat object (plywood in my case) right after the heat is applied. Remember that too much heat is not good as it will create burn thru holes and unless your going for that crispy look you will want to avoid this.
once the top is complete and your graphics are sealed in you should flip your project over and run the iron over the opposite side.
comments
Add Comment
Add Comment
