3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own remote power switches
Most people know about standby power (i.e. that many electronic devices continue to consume some power even when they are turned off). One way to eliminate standby power is to use a power bar or surge protector with a built in switch to turn off connected devices completely, but these are annoying and rarely get used in practice for 2 reasons:
1. Power bars are usually located under desks or are otherwise obstructed making the switches difficult to access.
2. The power bar switch controls all outlets on the power bar, but sometimes it is desirable to turn some devices off while leaving others on.
I build my own remote power switches to solve both these problems. I can turn off just the outlets I want with a switch placed exactly where I want it. See examples of some of my remote switch installations below. If you have enough mechanical and electrical aptitude to drill a hole and solder two wires together, you can make your own remote power switches too.
For information on this and other projects of mine see my website IWillTry.org.
Step 1Materials
Materials
Here are the materials to make an illuminated remote switch. A non-illuminated remote switch is easier but I prefer this style since it provides visible feedback as to the current status of the electronic equipment connected.
The materials are:
Qty - description - cost
1 - rocker switch Digikey part no CH809-ND - $1.24
1 - plastic enclosure Digikey part no HM375-ND - $1.60
1 - surge protector with removable back cover - $15
6ft - 14 gauge 3 wire electrical cord (should have black, white, and green wires) - $5.00
2 - 2" lengths of 3/16" heat shrink (not shown)
Notes:
1. Most power bars already have an illuminated switch. You could simplify this project by simply relocating that switch remotely, but I prefer to have a remote switch that only controls some of the outlets on the power bar allowing others to be "always on".
2. Costs for Digikey components decrease with quantity. It will also take you less time per unit if you build several at once. I purchased 10 each of the switches and enclosures for this reason.
3. This particular power bar was for a computer, so I used a surge protected power bar. Non-surge protected power bars are less expensive.
33 comments
May 11, 2012. 6:16 AMcrazy-blender says:
they should just make a rechargeable CMOS battery so when the computer is on it gets charged
Oct 8, 2011. 11:02 PMdewdrop01 says:
"$0.07 per kWh" amazing!
0.14 per kWh where i live
Aug 12, 2007. 11:59 PMgschoppe says:
Overall, this is a good idea, however, there are a few issues with killing all power to electronics that should be remembered.
1. computers : if i recal correctly, the BIOS battery is only under load when the computer is unplugged. Therefore, killing power to the computer would shorten the life of the bios battery (which is needed for power outages, upgrades, and moves) a dead BIOS battery can be a real bummer when they're soldered in, or in an impossible clip, and your power goes out
2. stereo equipment - on most equipment, clocks and presets are dead without standby. if not, your running a battery (or using non volatile memory, which is rare). In the long run, you're creating hazardous waste by killing batteries prematurely.
3. TV - say goodbye to channel programming and time. I'd hate to reset those everytime i wanna watch tv.
4. everything else - wall warts / cheap transformers are your biggest waste, in my experience... separating those out and switching only those would save almost as much electricity (imho) without the frustration... unless you have wall-warts for any of the above devices. the best solution would be a less wasteful transformer to replace all your wall-warts... I'll see what I can do... ;)
further wall-wart info (and warnings) http://www.glitchbuster.com/wallwart.htmhttp://www.glitchbuster.com/wallwart.htm
May 24, 2009. 9:55 AMlegless says:
CMOS backup batteries typically have a life of many years (up to 10). Unless it's a realy old computer replacing this battery is a minor task.
Apr 16, 2009. 11:34 AM1cardcreator says:
We keep the DVR cable box plugged in and cut the power to the TV with no time or programming issues. I have 1 very old TV that does have to reprogram when I turn it on, another TV also old does not have that problem. I use a clock for time, never use the TV for that.
Feb 27, 2009. 3:45 PMcptully says:
Good point about wall warts, but keep in mind that they are NOT all created the same. Specifically there are transformer based warts and electronic warts. FYI, the electronic ones are very light weight - they feel like feathers compared to the old transformer ones. My cell phone's electronic charger has been plugged into my Kill-O-Watt for 163 hours now and pulled a grand total of 0.00 kWH! Given this massive :) energy consumption, I am not really worried about leaving it plugged in all the time. My TV now... I wonder if I could add a battery and charging circuit to maintain time, channels etc, when I cut power? Computer CMOS batteries are under load when the computer is off, but it is a very small load. I can't give exact numbers but I can say that I've had computers turned off for months at a time without draining the CMOS battery!
Jul 9, 2008. 3:26 PMgormly says:
Just curious, is it mandatory on the internet now to point out flaws on everthing, even when most likley those flaws are irrelevant and do not need to be pointed out? I can't remember the last time I saw an electronic based instructable or otherwise without someone telling everyone not to do it (in so many words) Ugg, just let it alone man!
Feb 27, 2009. 4:57 PMmg0930mg says:
What;s your problem. I for one thought that gschoppe was very helpful.
Jul 9, 2008. 9:15 PMgschoppe says:
dude... i commented almost a year ago... talk about bumping old posts... however, I stand by my statements. I didn't, as is common, say "d00d dis projekt iz stoopid!", I in-fact have a very similar device attached to my OHP digital projector to control the LCD and lamp together. (built before this instructable came out) however, I think a straightforward discussion of pros and cons should be welcome in any situation where a change is suggested, especially a "green" change. Not clarifying those pros and cons yields a lopsided view of "consensus", and can confuse people interested in researching the change. In the past year, I have seen many articles warning of the "gluttonous" standby consumption of many electronics, and urging the reader to unplug... none of these articles seem to note that most standby consumption is minimal, and has a purpose. In an open comments venue, I felt (and still feel) that this information would be constructive. Making an informed decision before investing in a change is the heart of true "green" living, and too many people forget that... Its not about forgoing every convenience and living in a cave because the news told you to, its about deciding what cuts can be made to help protect the earth, with acceptable impact to your quality of life. To make such a decision, you must know the impact. BTW: the original poster replied in a well thought out manner, as to why it made sense for his lifestyle... Kudos to him, as that gave more information to those considering the change. Do you see how this is a positive thing yet?
Jul 8, 2008. 8:33 AMYoooder says:
Regarding your first note about the CMOS battery of computers: most Desktops use a CR2032 watch battery, which you can buy for $1-$2 dollars and typically are very easy to replace (just a matter of opening the case, typically using a flat-head screwdriver to pop out the old, and then pop in the new). However, you are correct that the battery can be a bummer if it dies--especially on newer machines. The battery allows the motherboard to retain it's basic settings (it's BIOS settings) without any external power. These settings on newer machines often contain the CPU and Memory speed settings, as well as settings that dictate if the machine will expect to see a 3 1/2" drive at boot. If the settings revert to default (which is what happens if the machine has no power and a dead CMOS battery) then it's very possible that your PC will underclock your CPU and Memory (i.e. will make the equipment run at a speed slower than what it is capable of or rated for). Fixing these settings can be a scary task to the computer novice, and can sometimes require removal of the CPU itself to verify the model number so that the proper settings can be researched.
Jul 9, 2008. 9:20 PMgschoppe says:
I LOVE the manufacturers that use CR2032s or 2016s in a simple clip. however, I've worked on at least 5 computers in the last year (I'm a technician) that were barrel cells, despite being relatively new machines. what's worse is that at least 3 had the cells soldered directly to the board, with a really tiny dot-pitch. Its still an issue, albeit most often with offbrand, budget PCs... or palm PDAs, or iPods, or........ oh, was I rambling, sorry, I get like that...
Aug 14, 2008. 6:10 PMbikerbob2005 says:
even worse the barrel cells leaked goo onto the mobo rotting it out another coppermine goes to the dump :(
Aug 16, 2007. 12:50 AMYerboogieman says:
you can do on an old transistor radio.....
May 20, 2009. 2:15 PMgpulley says:
Iwilltry; great idea and your submission is well written. But I'm concerned about safety (and potential liability for those who aren't versed in electrical engineering). This mod is definitely not IEC code compliant. Specifically, you need to either use a UL-listed switchbox and conduit for your remote switch, OR as some others have suggested, switch the load with an appropriate relay or solid-state switch (TRIAC) controlled by a low voltage control circuit. -G
Aug 12, 2007. 6:47 PMMisterSlippy says:
You could replace the switch with a an inline fuse and a 10Amp Relay with a 12v coil, powered by your PC's 12V from the power supply. That way, when you shut down the PC, the peripherals go off automatically. It's what I did with my setup! ;-)
May 6, 2009. 3:21 PMthetech101 says:
That's an awesome idea. I might try it myself. Thanks for the idea!
Aug 12, 2007. 6:48 PMMisterSlippy says:
Still a cool instructable, btw. :-)
Aug 12, 2007. 6:56 AMPatrick Pending says:
Nicely explained instructable and a good idea. I am going to sort out my home video equipment. I will use a simpler method though: I will use two power bars with one of them plugged into a wireless remote control switch. BTW: They use neons with a series resistor in illuminated switches. You can't connect an LED directly across live and neutral without frying it!
Aug 12, 2007. 1:44 PMPatrick Pending says:
A typical LED would have reverse voltage rating of only 5 Volts.
May 6, 2009. 3:19 PMthetech101 says:
It depends. Some LEDs have a reverse voltage of 2x their forward voltage. Some it's half. Some it's more or less. It all depends on who manufactured them.
Apr 26, 2009. 10:42 AMQuake10.0 says:
I have a similar setup, only that mine is built into my computer desk.. When I am through with the computer I just turn my switch off and it turns off power to every thing including two computer systems. Wanted to add image but camera batteries went dead. Will post image later.
Mar 27, 2009. 10:50 PMBlackHatCracker says:
Instead of tinning the ends of the wire, all you would need to do is get a few quick connects and crimp them onto the wire. Then connection would be easier if you aren't too sure of yourself in using a soldering iron.
Feb 27, 2009. 4:19 PMpicklegarden says:
This is really neat. I just did something like that in my workshop. A switch on the desk turns the lamp on. The switch for my is mounted on the desk.
Feb 21, 2009. 10:14 PMcasey321b says:
but when the tv gets turned off it flips through all the channels and makes you wait 1 WHOLE MINUTE BEFORE WATCHING TV. plus the clock inside doesn't work when its not on and WHAT WOULD HAPPEN IF ALL THE CLOCKS STOPPED WORKING!!!! AUGH!!! I really dont like waiting plus i dont liek changing to channel 99 just to see what time it is. but i guess it would save power and with the power you save you could run a clock!!! then no more changing to channel 99!!! YES!!!!
Mar 22, 2008. 7:31 AMstraycat5150 says:
Thanks for the Instructable!. I used your example and used a simple 6 outlet surge protector and relocated the existing rocker switch to the remote position.
Sep 19, 2007. 8:37 PMincorrigible packrat says:
Neat! I always hafta stick my power bars in awkward, stupid places, cuz wifey don't like lookin' at all them cords and plugs n' such. Also, the power bar usually comes with a stoopid short cord (to keep those dinks that plug fifteen different high current doodads in there and use 'em all at once, from a' burnin' their houses down) Now, I can hide the power bar, and put the switch wherever I damn well please. Also, I can use up some of the old coffee maker power switches, I've accumulated over the years.
Aug 12, 2007. 12:39 PM!Andrew_Modder! says:
Aug 12, 2007. 9:56 AMTossManual says:
I like this, but wish you had shown your "split" version - you know: some on, some off - for us newbies. Also, the problem with turning off TVs and VCRs completely is losing all the programming. That flashing 12:00 drives me crazy.
Aug 12, 2007. 10:53 AMlemonie says:
I've got a Dell like that at work. L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:iwilltry(IWillTry.org)
I have a B.A.Sc and M.Eng. from the University of British Columbia, specializing in electromechanical design, but mostly I like to tinker. One of my greatest passions is energy conservation and effici...
more »
