I make lots of stuff that needs springs. I have always hated trying to find the right spring for the job in a hardware store, then having to pay up to 10 dollars for it. When I was learning to make chainmail I came up with this method for winding rings and realized it could be used for making springs as well. It is insane how quick and easy this is.
Video makes this easier to follow and shows just how ridiculously fast it is, so I included a podcast with me doing this. The spring segment is at 5:19 but don't be shy about watching the rest of the video afterwards, not to mention other episodes. also, don't forget to check out my other instructables.
Remove these ads by
Signing UpStep 1Materials
Heavy duty gloves, not gardening gloves. I use welding gloves. If you try this with light duty gloves, call an ambulance before you start so it will arrive in time to stop the bleeding.
An arbor- just a fancy name for a rod to wind the spring on, round is common but not required. Match the arbor to the diameter of the spring you want to make.
You may need a piece of square steel (I used 1/4" keystock) if you want to make a compression spring. More on this in a minute.
I have 3/32" stainless steel tig rods for welding sitting around. Each rod only costs a few cents and they seem very suited for doing this kind of hand bending. while still being stiff enough to be a spring.
Anyone who knows how many pounds or newtons of force they need for their application should plug their numbers into Hooke's Law to calculate the parameters needed to create their spring (BEFORE bending some random piece of steel wire). More info on this is here.
But for a pretty good article on tempering, see here. It touches on both oil and sand bath tempering.
Tweeks
in quite a dangerous way.
I've done similar to this when making chain maille links. but I use an arbor in like a spit roast design between two wooden blocks and hand crank slowly, carefully and deliberatly.
Juggling with power tools is all fun an games untill someone gets the nick name Ace.
I wish people would stop telling me I have "only coiled a piece of wire". Prove me wrong by making one yourself. My stainless springs have functioned for years with no sign of wear. how do you think they make springs for use in the food industry?
I dont need to prove you wrong. I am merely trying to educate you.
when making chain maille links this is the quickest way to coil the wire for uniformed links I would then stretch it out before cutting links. It would appear similar to the way you've coiled your wire. Both in aluminum and steel.
the reason myself and tweeks brought this up was because from a metallurgical stand point its just not sprung. Therefore It would be wrong to call it a spring. If you compressed it from its original length to its minimal length you would notice it would have lost length in just 1 compression. possibly with some parts buckling more than others.
I know how they make springs for the food industry since I've worked on many projects outfitting factorys and belt systems. Same ways they make all springs as mentioned by tweeks heat the metal up to a calculated temperature and quench it in oil
PS: A word of advice when using rotating machinery such as a hand/pillar drill DO NOT Use Gloves. Same goes for using any abrasive wheels... thats shop safety 101
do you want to look like seamus from family guy?
Make one out of stainless and show me that it does not work.
The basic winding technique is as I expected, but using a jaw of the drill chuck to anchor the wire is a trick I hadn't seen. Many wind wide spaced inductors by winding another wire, rope, string or cable with the desired wire, discarding it after the inductor is wound. Perhaps the same technique could be used to wind a compression spring. All in all a good instructable, but please consider to the point video production in future instructables. Also keep in mind video doesn't work well for those poor souls still stuck with dial up internet connections Thanks...
If you mean using aluminum as a spring, you can coil it into shapes this way but it will not really become a spring. If you compressed or stretched it it would not return back to its original size. You need a "springy" material. spring steel works best and stainless is pretty good. aluminum and brass are just too soft.
Some times we would make special custom springs by soft annealing standard off the shelf springs and straightening them to salvage the wire. Then we would rewind them to suit the job at hand and re-temper.
Dave used stainless steel wire to make the springs. Most stainless steel is already hard enuff to do the job. So heat treating is not necessary. If you heat treat the stainless it will be too brittle. Now something like mild steel would be a different story.
Again, very clever instructable!
Then again I whistle when I talk now....
This is a great instructible - I've always thought it should be possible to make your own springs, but making them entirely by hand, it's difficult to get the right tension. A drill is the perfect tool!
The springs you've made avery neat and proffessional-looking. Have you tried different kinds of wire/rods? Can you make very fine springs this way?
The instructible would be easier to use if you put in more details, for example:
- what is the correct position for the arbor and the rod in the drill chuck
- is the drill on drive (clockwise) or reverse?
- what torque setting works best?
- how do you hold it safely in position as it spins?
I guess I can work all these things out when I give it a go, but it'd make me feel more confident if I knew exactly what I was trying to do!
Thanks for a great tip
Jethro
I'm wondering for the compression springs, it must be possible indeed to make a sort of holder with the spacer inside. Should make it a lot safer and you can make bigger holders to use on bigger wires...in which perhaps you can make them on a lathe at very slow speed!
