3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own springs in seconds
Step 3Compression springs
Compression springs
Compression springs are ones that squish, like the spring in a ballpoint click pen.
Making these is almost as easy.  Start the same way and make a few turns of an expansion spring (wire touching itself).  Then wrestle the spacer (keystock) in between the last turn and rest of the still straight wire.  Spin a bunch of turns with the spacer and then finish it with a few more expansion turns.  Slide it off the arbor, clip the ends and you are done.
If you made it this far, you might be interested in our facebook page
6 comments
Dec 4, 2009. 7:46 AMbof2b says:
what about tempering the steel so that it remains springy?
Dec 5, 2009. 10:33 PMTweeks_tx says:
The point here is Dave that you have not actually created real springs.. but just showed a cool way of bending steel in the first stage of making a spring.  To be able to have a real spring you must temper the steel.  This is especially true with springs that are going to have any reasonable about of force applied to them.
Anyone who knows how many pounds or newtons of force they need for their application should plug their numbers into Hooke's Law to calculate the parameters needed to create their spring (BEFORE bending some random piece of steel wire).  More info on this is here.
But for a pretty good article on tempering, see here.  It touches on both oil and sand bath tempering.
Tweeks
Apr 27, 2012. 10:32 PMdconnolley says:
I'm glad someone brought up this point. all he's done is coiled a piece of wire.
in quite a dangerous way.
I've done similar to this when making chain maille links. but I use an arbor in like a spit roast design between two wooden blocks and hand crank slowly, carefully and deliberatly.
Juggling with power tools is all fun an games untill someone gets the nick name Ace.
Apr 29, 2012. 8:56 PMdconnolley says:
to a small degree it would behave similar to a torsion spring.
I dont need to prove you wrong. I am merely trying to educate you.
when making chain maille links this is the quickest way to coil the wire for uniformed links I would then stretch it out before cutting links. It would appear similar to the way you've coiled your wire. Both in aluminum and steel.
the reason myself and tweeks brought this up was because from a metallurgical stand point its just not sprung. Therefore It would be wrong to call it a spring. If you compressed it from its original length to its minimal length you would notice it would have lost length in just 1 compression. possibly with some parts buckling more than others.
I know how they make springs for the food industry since I've worked on many projects outfitting factorys and belt systems. Same ways they make all springs as mentioned by tweeks heat the metal up to a calculated temperature and quench it in oil
PS: A word of advice when using rotating machinery such as a hand/pillar drill DO NOT Use Gloves. Same goes for using any abrasive wheels... thats shop safety 101
do you want to look like seamus from family guy?
Dec 30, 2010. 5:47 PMsniperHunted says:
will this work with an aluminum or brass rod?
Jun 5, 2010. 8:48 PMusmarine24 says:
Great instructable dude
Dec 4, 2009. 2:56 AMkube60 says:
You don't do any heat treating afterward?
Dec 4, 2009. 1:32 PMSpokehedz says:
 Usually just bending the wire 'works' the steel enough to make the spring stay in shape by itself.
Dec 3, 2009. 9:38 AMchrispix says:
When you're doing a compression spring, are you moving the spacer up the arbor as it turns, or does the spring wire push it up the arbor for you?
Dec 3, 2009. 11:37 AMjamwaffles says:
I would imagine the spring wire pushes the spacer up the spring
James
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
101
Author:dave spencer(www.mechanicalmashup.tv)
I have had a few careers so far, soldier, school teacher, arborist, millwright. I love change and I love learning.
