What you'll need:
A printed out image
A Box Cutter
Foamboard/Cardboard
Sandpaper
Toothpicks
Hot Glue Gun
Duct tape (of course)
Spray Paint
Latex Gloves
Also, my image is relatively simple, but if you want to use one with spereate objects, use this tutorial with mine.
Oh, and this is my first instructable, so be constructive, but not too harsh.
Remove these ads by
Signing UpStep 1: Preparation
Print out whatever image you want to use, and tape it to the foam board.
Step 2: Cutting
Step 3: Sand and glue
Use your hot glue gun to make the inside of the stencil extra smooth. Draw a thick line, then use your tooth pick to spread smooth.
Also use tooth picks to reinforce any delicate parts, or parts the fell off while sanding. Youll notice I had to reattach part of my W.
Sorry for the blurry image.
Step 4: Test it out
Add a few layers of duct tape to the back for some padding
Hold the foam board extra tight to the peper
Use glue to make a thick line along the border to catch overspray.
Again, this is handmade, so there will always be some.
Go Pro Today »
I have also used frisket on walls for my bigger stencils. it hold them in place, completely blocks paint leak-through and the best part for me is- you can cut while it's on the wall and it doesn't stick permanently and you can move it around and re-use it.
wow I dont have a glue gun ,what am I soupost to do?
depending on what spray/surface your using, it is best to read the instructions on the can, but in any case, dont spray and then place it immediately. better spray, wait a couple mins, then place it on. if you do it to soon it will bond too well for your purposes.
