Make Your Own Sunglass (or Eyeglass) Parts on a 3D Printer
Published
Introduction: Make Your Own Sunglass (or Eyeglass) Parts on a 3D Printer
Both the temples on my new sunglasses broke!  The design has a weakness that  will most likely cause any repair or replacement temples to break in the same place.   The problem is the Elvis/Vegas-look metal insert.   When the temple flexes, the stiff metal forces all the load to the hinge area- which then cracks.
So I designed and built replacement temples that I like better than the originals.
I just built the temples, but the entire frame could have been made with the same techniques.
Step 1: Materials and Equipment
Materials
Printing plastic filament- I used ABS for prototyping purposes, but nylon is recommended as it is less likely to shatter on impact.
Equipment
3D Printer
Software
3D CAD design software - I used Autodesk Inventor
Step 2: Analysis
Now I had to figure out what I liked about the original temples, and what could be improved.
Liked:
-Color matched the rest of the frame.
-Flexible plastic- pretty sure it is nylon.
Disliked:
-The metal insert created a breakage problem.
-The metal insert design did not appeal to me - a bit too Euro-Elvis (sorry Jean-Paul).
-The temple ends curved in too abruptly- created stress on the hinge and denting my skull
So I needed  temples that were a bit longer and would  have a more gradual curve.  The fit needed to be secure enough to use for recreational activities.     Color matching would be difficult- so maybe a complementary color instead.
Step 3: Design
1.  Measure the dimensions where the existing temples connect with the frame.
2. Determine the proper length and curve for the new temples.
3.  Draw!   I created a horizontal profile view, extruded the horizontal, and  then projected a vertical view  that was cut-extruded from  the horizontal.     The  edges were rounded using a variable filet feature.
If I did it again, I would probably draw a wireframe and loft the shape.
Step 4: Print & Assemble
Off to the 3D Printer.
I used ABS filament at fine resolution with 4 shell layers and 90% infill.
The holes for the temple screws were fairly small, and therefore needed some touch-up with a roto-tool.
The temples screwed right into the frame and fit quite well!
Step 5: Observations
So far, the self printed temples have held up quite well.   If I decide I like this prototype version,  I will order a resin based print out of nylon.  I think I should play a bit with the filet to have it match the profile at the joint a bit better.
This effort has inspired me to consider designing my own frames for prescription sunglasses.  I have not been able to find what the requirements are for the frame shape to be able to support standard lens blanks.  I suspect this could get tricky for 6-8 base curve lenses.  I would definitely not use ABS, and instead would web-order nylon/resin prints for a a full frame.  Nylon would probably be a bit more forgiving on impacts, and better for inserting/gripping the lenses.
The photo is an alternate design- looked nice, but the  temples were a bit too long for my taste.
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
