3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own top water minnow fishing lures
Inspired by msolek's instructable and looking for a simple excuse to use my lathe, I decided to knock out some fishing lures. These are alternately know as"Stickbaits" and "Cigar baits".
Step 1Selecting your wood
Selecting your wood
You'll want to select a fairly low density soft wood for your lures, Spanish Cedar is a classic choice, but any cedar or pine should work fine.  Start by ripping the wood into 3/4 inch square by 6 inch pieces.
21 comments
Jan 15, 2012. 10:07 AMkjemielity says:
nice baits! for those of us with no lathe, pre-turned tapered furniture legs work just fine.choose your wood carefully,tho...some varieties dont float as high
Dec 24, 2009. 9:57 AMnathan43081 says:
I was wondering if you have ever had issues with the hardware coming off when a fish hits the lure. It seems that using a soft wood might have problems here. This is a very nice instructable and I would like to try it myself, but am worried that when a decent sized trout hits the lure it won't hold up. Thanks.
Jun 24, 2010. 4:47 AM92033 says:
Use a full length piece of stainless steel wire through the length of your lure, with enough extra sticking out at top and bottom ends. Make wire loops with twists using needle nose pliers and no matter how big the fish biting it...it wont come apart as the wire is one piece from end to end. You can already buy the stainless steel wires precut to various lengths, or buy a spool at your local hardware store and cut to sizes accordingly. You predrill a hole through the lure to insert the wire, make your twists and connections.
Oct 17, 2010. 7:01 AMguitarmv says:
Yes, that.
Oct 17, 2010. 7:00 AMguitarmv says:
Nice work! I suggest drilling through the center, inserting an appropriate-width ss wire, and attaching your tackle to that wire (i.e. one end of a small swivel).
Wood explodes if the fish hits or fights it right, or can pull tackle (on rocks, logs etc).
Attach your tackle to the wire, and no matter what happens to the wood, you will (hopefully) still have a fish at the terminal of your endeavor.
Apr 10, 2010. 7:39 AMgeodez says:
you should have made the white one in the white with red head pattern.
Apr 10, 2010. 7:37 AMgeodez says:
i always wondered why a helin flatfish had 4 hooks instead of 2.
Apr 10, 2010. 7:36 AMgeodez says:
balsa?
Jan 14, 2010. 11:19 AMscavanger says:
 Tool Using Animal
Great job on this post! I liked is so much I included it in a blog post I did, I thought you may like to know.
I also wanted to remind everyone to click the stars above and rate this post!
Thanks again.
Dec 26, 2009. 8:15 PMmeddler says:
I've made a bunch of spoon lures using...Spoons. I buy a bunch at a thrift store and cut the spoon part off and grind it down a bit then drill holes at both ends for treble hook and swivel. I have caught just as much fish as my friend with his store bought spoon lures.
Dec 27, 2009. 3:53 PMmeddler says:
Hmmm, stepped right in it didn't I?
Dec 26, 2009. 1:53 PMBardouv says:
 Interesting and inspiring, yet I don't have a lathe, or a drill press. I suppose I could whittle, but that'll prob'ly take forever.
Dec 27, 2009. 8:50 AMpaganwonder says:
As with all skills whittling requires practice to become proficient.  Keep practicing and before you know it you will be able to whittle a lure that is straight and true without really thinking about it.
Another option would be to check out noho91 on youtube- he makes really cool stuff without all the proper tools.
Dec 25, 2009. 1:20 AMdavee52uk says:
Nice one. I think you could use balsa wood for the body and also paint it using an airbrush.
Dec 24, 2009. 3:09 PMlucek says:
I have a friend that makes and sells lures. he specializes in ones like lobsters and rubber ducks. makes them in a silicon mold.
Dec 24, 2009. 8:18 AMBen.land101 says:
 First of all, nice Instructable. second of all, you could leave the bill off altogether and have more of a Zara Spook. (one of my favorites)
Dec 24, 2009. 7:56 AMNachoMahma says:
.  Very good iBle.
Dec 23, 2009. 10:05 PMAtrophius says:
Nice job. If you ever want to check out some other home made lures, I am a member over at tackleunderground.com  They are some additional tutorials on how to do more lures.
Dec 23, 2009. 8:26 PMKnexFreek says:
kewl! nice ible ! 5stars
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
