Make Your Own Tortilla/press
2,140
19
Published
Introduction: Make Your Own Tortilla/press
About: A mechanical engineer, instructor at Thaddeus Stevens College, and lifelong maker. Thanks Dad! A founding member of make717. Check them out at www.make717.org
yes, tortilla's are easy to purchase and make into great food...but why not make it even better? Do you want to make your own tortilla's but don't have a press?
Inspired by "Tortilla Press" by kuhldad on instructables...with some great design inputs from my son (soon to be a graduate chef from Culinary Arts of America, please hire him!) and my father in law...it only took 1 trip to Home Depot and about an hour of assembly.
Step 1: Tortilla Dough
Recipe:
Mix masa with water and salt...it should be like play dough. When you smash a ball down it shouldn't crack on the edges.
The world's easiest recipe!
Step 2: Make Dough Balls and Load the Press...
Roll the dough into balls, press and determine if the size is correct for the dish you are making...I am often the victim of overstuffed tortilla's, so I advocate large diameter...something like 10".
Line the bottom and of the press with cellophane, deli paper, or other food safe material that will keep the tortilla's separate and prevent sticking to the press. Place the ball nearer the hinge side, if you are too far away from hinge you will get a wedge shape (not even thickness).
From there it doesn't get any easier, close, the middle layer, then close the top. The weight of the wood will press the tortilla.
So how do you make your own press?
Step 3: The Press.
We went to Home Depot and purchased 3' of 12" wide, and 1" thick poplar. Make sure the board is flat. I realized afterwards that the saw operator probably could have cut us the 3 individual pieces.
The only other items we needed were hinges. Because the wood is actually 3/4" thick we got 4 hinges that were 1.5" and also 2 - 3" for the triple side. See the sketch for how these are attached.
From there I used 2 different "things" from Thingiverse:
A handle:
http://www.thingiverse.com/thing:670763
and knobs on the side to open the middle layer:
http://www.thingiverse.com/thing:600955
Step 4: We Had Some Awesome Fish Taco's...
what will you have with your home made tortilla's?
Making and food does go together!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    2 Comments
    I've always wanted to make my own tortilla press. You may just have inspired me!
    my making and foodie family don't often intersect, this was an incredibly easy project. my son figured out the easy tri fold approach...much simpler than other instructables I have seen on making a press.
