loading
This will be a multi-part guide on how to build your own websites. I will cover everything from basic HTML code, to the more advanced PHP code, to using GUI editors to make your process faster. This first part will cover using basic HTML to make simple pages.
I will assume you know basic computer terms, such as browser and server, but not necessarily specific code or things like HTML editor (or even HTML). If you don't know what they mean, look them up on the internet (I will defiantly assume you know what that means, as you are using it).
Also, I will not be posting pictures in this guide, as they are quite irrelevant. Instead, I will be providing links to web pages used as examples.
To view the code that the example web page used, right click anywhere in it and click either "View Source" or "Page Source" (depending on the browser).
Let's begin shall we?
Step 1: The Editor
In order to build a website, we need some sort of editor to use. This is where we will type and edit the code. Some editors allow you to view the web page as you type the code, and some are just plain text editors. Some will highlight syntax (another name for code).
If you can afford it, the best HTML editor you can buy (in my opinion) is Adobe Dreamweaver (formally Macromedia Dreamweaver). Other good editors include FrontPage (included in some versions of Microsoft Office) and CoffeeCup.
There are many free HTML editors out there though. I personally use KompoZer , it is free and similar to Dreamweaver. Another free one is Notepad (comes with every version of Windows), just remember to save the file with a .html ending instead of the default .txt.
Step 2: HTML?
If you haven't guessed already, the coding language we will be using in this guide is HTML. But what is HTML?
HTML stands for HyperText Markup Language. It is a very simple language that is a part of every website. Some people make full websites out of HTML, while others will add other code to it.
HTML uses a set of simple English words to make it easy for a person to write it. Words like body, img (image), head, and table are just a few examples.
Step 3: The beginning of a website
OK, now you have an editor and a little knowledge about HTML. Lets get started.
Open your editor and make sure you are on a page you can code (might be the source or code tab on GUI editors)
Make sure it is blank before starting. Some GUI editors add information to the code.
The beginning of every HTML page must start with the command <html>. This can be written as <HTML> <hTMl> <Html>. It doesn't matter. Capitals are exactly the same as lower case in html.
The ending of every page will end with </html>. The forward slash signifies the end of any command.
So far your page should look like this
*-*-*-* - Signifies code. Ignore the starts and dashes
<html>
</html>
View this as a webpage
Nothing to see so far, but technically this is a webpage.
Step 4: The body of the page, and some words
In order to put things in the main part of a web page, we must use the command <body> and the ending command </body>.
<html>
<body>
</body>
</html>
Still nothing to see. We must add some text in there. For text you just type what you want it to say. There may be only one space between each word (other spaces are ignored) and new lines (enter key) will also be ignored.
<html>
<body>
Hello World.
This will be on the same line as the Hello World.
So will this!
</body>
</html>
View it
At this point you will not be able to use certain symbols (such as the < and >). We will cover those later.
Step 5: Line breaks
Until now we haven't been able to see our text on separate lines. This is easily fixed with the <br> command. The <br> command is one that does not need an ending command (there is no </br>). Some people feel it is more correct to use the command like <br />, which is still proper code. I personally find it a waste of time to add the extra slash in it.
Our code can now look like this.
<html>
<body>
Hello World.<br>
This will be on the second line.<br>
<br>
<br>
This will be on the 5th line.
</body>
</html>
View it
Step 6: Title the page
If you look up at the top of the browser, you should see that it says "Make your own websites - HTML basics (Part 1) - Title the page - Instructables - DIY, How to,..." This is the title of the web page.
In order to change anything outside of the body, we must first use the <head> command (ending with </head>). This specifies that you are changing the header of the website, and not the body. The <head> command goes between the <html> and the <body>.
It should look like this:
<html>
<head>
</head>
<body>
Hello World.<br>
<br>
<br>
</body>
</html>
To add a title to the page, we put the <title> and </title> in between the <head></head> tags (tag is another word for command in HTML). The title itself goes between the <title></title> tags.
<html>
<head>
<title>This is the title of the page</title>
</head>
<body>
Hello World.<br>
<br>
<br>
</body>
</html>
View it
Step 7: Font
To change the font of the text we use...
... you guessed it. The <font> tag. As with most tags, the font tag has what I call subtags. They are little parameters that allow you to change something in that specific tag.
The font tag has many "subtags". Here are a couple common ones:
color - Allows you to change the color of the text. You can use regular words for colors (red, blue, etc) or you can use hexidecimal colors (#FF8CE3)
size - Changes the size of the font. You can use standard font size numbers, or you can say that you want it 3 font sizes bigger than the current font by typing +3.
The proper syntax is as follows <font color="red" size="+2"></font>. Subtags may be switched around in the tag. This would also be correct <font size="+2" color="red"></font> and would do exactly the same as the first one.
Lets put some font into our code.
<html>
<head>
</head>
<body>
Hello World.<br>
<font size="+2" color="red">This will be on the second line and will be bigger and red.</font><br>
<br>
<br>
<font color="blue">This will be on the 5th line and blue.</font>
</body>
</html>
View it
Step 8: Adding pictures
Adding pictures is pretty simple. We will use the <img> tag. To display a picture you would type <img src="xxx.jpg">. After the src subtag, put the address to the picture (URL). You can only use JPG, PNG, or GIF (some browsers support more types of pictures, but these 3 are the standards).
Lets add a picture to our code:
<html>
<head>
</head>
<body>
Hello World.<br>
<br>
<br>
<br><br>
Lets put the instructables robot in our sweet page.
<img src="https://www.instructables.com/files/deriv/FOI/P4EJ/FD80X5Q0/FOIP4EJFD80X5Q0.MEDIUM.gif" />
</body>
</html>
View it
Step 9: Links
Links are also pretty simple. You use them to allow someone to click to another page. You will use the <a> tag and the "href" subtag. It is used like this: <a href="http://www.website.com/link.htm">Text you want to make a link</a>
Let's try it out:
<html>
<head>
</head>
<body>
Hello World.<br>
<br>
<br>
<br><br>
<br> Lets make a <a href="https://www.instructables.com/member/Instructables+Robot/">link</a> to the instructables robot's web page.
</body>
</html>
View it
Step 10: Read part 2
This is the first part of a series of them. Check back every once-in-a-while. I'll post a second one soon and I'll link to it here on this page.
Hi I have a to make something to my school as a project <br> <br>The question is &quot;for your next PAT (practical assessment task) you will have to find out if you can create a web page in css, but not any web page you can chose from 3. <br> <br> Number 1 find out if you can make a member page that show the members and allows you to log in as one or to become one. <br> <br> Number 2 find out if you can create a page where you can upload files but it must only be available to members same for the downloads. <br> <br> Number 3 find out if you can use css to create a web page or a section of the web page were a random anonymous person can donate money. <br> <br>Remember this is all in css <br>Have fun.&quot; <br> <br>That is the question we have
how do you veiw it?
simple with windows just press F12 on windows 7 or higher
you have to get a host....
orpreview it in firefox/opera/IE...etc
how do i preveiw it<br />
please <em><strong>answer </strong></em>the following question:<br /> <a href="https://www.instructables.com/answers/Is-there-any-HTML-30-software-editors-that-work-c/" rel="nofollow">https://www.instructables.com/answers/Is-there-any-HTML-30-software-editors-that-work-c/</a>
i want to make a web site so that i can host my FTP...i dont want anything fancy, i just want like a list.....would html do the trick?
When i use the backround code down there, on my website, it doesn't do anything, but form my computer, it works. Is there a way to use a URl for the backround?
i forgot the code for image backgrounds. and whats the code for music embedding?
i will show what is the code for image background in html&lt;br/&gt;code:&lt;br/&gt;&lt;br/&gt;&lt;body background=&quot;your image.jpg&quot; width=&quot;100&quot; height=&quot;100&quot;&gt;&lt;br/&gt;&lt;br/&gt;but it is more better to use css(cascading style sheet)..&lt;br/&gt;code:&lt;br/&gt;&lt;style type=&quot;text/css&quot;&gt;&lt;br/&gt;body&lt;br/&gt;{&lt;br/&gt;background-attachment:fixed;&lt;br/&gt;background-image: url('your image.jpg');&lt;br/&gt;background-repeat: repeat;&lt;br/&gt;}&lt;br/&gt;&lt;/style&gt;&lt;br/&gt;note: embed this code before typing the body( &lt;body) tags.&lt;br/&gt;&lt;br/&gt;<br/>
what would it be if you want to use a hexadecimal colour?
are you asking how to place a hexadecimal color for background like if you want to put a white background it is simply #ffffff<br/>sample:<br/>&lt;body bgcolor=&quot;#ffffff&quot;&gt;<br/>note: the # sign is important and in putting hexadecimal colors are limited to 6 letters. 6, 3, 9 , f , 0 - hexadecimal signs<br/><br/>do not use this:<br/>&lt;body background=&quot;#ffffff&quot;&gt; <br/>
thats what i wanted. i forgot how to do that. i need to brush up for computer apps 2.
rea, just a suggestion- it is more compatible to use css (cascading style sheet) for background and design.
how about PHP (probably a dumb question)?
PHP is a good scripting language. if you want to learn PHP, you should also learn MySQL-for database.
i heard that learning MySQL would be good. ill give it a shot!
today i use MySQL as my database in PHP and VB.net Programming.
what does the !DOCTYPE! exclamation for/ how do you write it ( know what to write)?
backgrounds
Cool I did an instructable on making your own site aswell, except mine was aimed at the no coding approach, with dreamweaver, which I personally love... Nice instructable, more in depth than mine, which was designed as a very basic 'first timer' idea that worked well using tables etc.
the thing about dreamweaver is that you have to pay so much to get it. the full package (flash, dreamweaver, fireworks and the others) is about £700!!! no way am i paying that much for it
Dreamweaver can be had for free and legally in a huge number of ways, school can license to students willy nilly if they want, some businesses that use it give you a code and everything if you do work experience with them, friends that own it for work purposes can add your name without breaking license...
<pre>yes but when he buys the license he buys a certain number,and when you activate it over the internet it checks whether thelicense has expired. so you can only use it a certain number of times</pre>
Aye but he ended up with hundreds of goes so...
Please make the next one I need to know cause I already mastered this stuff.
The very basics of HTML are pretty easy. Knowing the best way to put things together is the hard part. For example you'll find yourself asking "should I do this in CSS or in HTML?" or "should I make a frame or a table?" One answer or the other is usually better in the long run and one is usually easier to code. To answer these and other questions for you and your website you really need to do a lot of reading and asking questions. I have not built a website from scratch in a several years (time flies). I need to look at XHTML. Good Instructable. I can't wait to see the rest. You might try skipping a line between your statements. With all the HTML punctuation, it is hard to follow.
The answer to those questions being "If you can do it in CSS, you should," "Never use frames. Ever. (They're bad for many, many reasons)" and "Only use tables to display table-based data. Don't use it for layout." Really, the only differences between HTML and XHTML are that you have to close your tags, tags all have to be lowercase, and all text has to be inside a tag (<p> or <h2> or whatever).
hi good instructable how can i put one of the little icons next to the web address
All in good time. I will cover a whole lot about website making in the future. <br/><br/>All though I suppose I could give you a bit of code early. Try this:<br/>******<br/>&lt;link rel=&quot;Name of Icon&quot; href=&quot;picture.ico&quot; /&gt;<br/>******<br/>It must be in .ico format though.<br/>
And a thousand web professionals cringe that you're teaching people the <font> tag. ;) But what can I say? I'm a stickler for standards. XHTML, and all that. So for me, <br /> is the only option, because <br> isn't valid in XHTML. But really, it's not a bad instructible. I kind of wish you'd spent some time explaining the difference between the head and the body, though.
Oh, I forgot: Are you going to cover CSS in the future, or are you going to stick with HTML?
Don't worry. I plan to go into it all. We will cover HTML, DHTML, CSS, PHP and maybe a little JavaScript.
About This Instructable
6,839views
44favorites
License:
Bio: A current student at the University of Advancing Technology. Currently studying Robotics and Embedded Systems.
More by bmlbytes:Installing Subwoofers in a Car Create a PDF Make your own websites - HTML basics (Part 1)
Add instructable to:
