3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own whistle
How to make your own whistle. With this instructable we can free America from it's dependence on foreign made whistles.
Step 1Get wood
Get wood
Got wood? Great!
I used a "pen blank", that's a 3/4 x 3/4 x 5 inch piece of wood. Woodcraft sells a five pound grab bag for $13, so I have plenty of wood.
In addition to the wood, you'll need a 5/16th drill bit and a 5/16th hardwood dowel.
You can start by drilling a 5/16ths hole down the center of your piece of wood. How deep? Less deep than the wood, or if you need exact numbers, the hole should be x-1 inches deep, where x is the length of your piece of wood. Use a drill press and a vice, if you choose to freehand it, please clamp the wood in something, you don't want splinters do you?
69 comments
1-40 of 69next »
Feb 27, 2012. 9:09 PMmistyp says:
Very helpful Instructable, thank you! I used this as a launching off point for making a whistle pen :-) I also linked to your tutorial.
http://www.instructables.com/id/Transform-a-ballpoint-pen-into-a-survival-whistle-/
Feb 26, 2011. 1:44 PMDarksabre says:
I'm sorry, Maybe this has already been asked - or maybe you already pointed this out - But what is the wood you are using for this project? The grain is fantastic!! Great Instructable :D !!!
Aug 24, 2010. 4:07 PMthepelton says:
One thing you could do if you don't want a square whistle is to use a windfall piece of wood. Elm and Paulownia cure nicely without a lot of cracking. A good rule of thumb is to set it aside for one year for ever inch of diameter. A whistle size piece would be useable in about half a year. I am sure that some other people could make suggestions as well. Well...?
Sep 24, 2009. 2:19 PMiamlopainus says:
MY WHISTLE ISN'T WORKING!!!
Aug 23, 2010. 11:39 AMthepelton says:
One problem may be that the angle isn't sharp enough. The wedge of wood that the air blows onto( = /) has to be very sharp. Look at and study a finished, working wooden whistle to get it right. I would say it has to be about 22 degrees to work well.
Aug 23, 2010. 2:32 PMiamlopainus says:
thanks
Mar 24, 2008. 3:09 AMoffseid says:
Very cool. I would have appreciated a brief "what to do" for those of us who don't have a lathe but would like to have something other than a rectangle for a whistle. As for me, I think I would maybe chamfer the corners with my chisel (and then maybe chamfer again), and then go over it with a rasp. Never done it, so I don't know how it'd work, but I think that's what I'd do. Nice one, though!
Mar 26, 2008. 8:49 AMCharles IV says:
just use a dowel instead of the rectangular piece.
Aug 23, 2010. 11:43 AMthepelton says:
I have made whistles in wood with a round hole, and a piece of dowel for the mouthpiece that is sanded so that it lets a little air in by a hole that looks about like a crescent moon or fingernail clipping.
May 6, 2008. 4:52 AMMarco hernandez says:
Tool USing Animal that is so cool that you show me how to make a whistle.
Apr 7, 2008. 1:19 PMfunwithfire325 says:
be carefulL! you might kill yourself when u use that saw!~ can i have your stuff then?
Mar 24, 2008. 7:41 PMoffseid says:
Yeah, good call. A chisel would not give you a very uniform chamfer.
Mar 25, 2008. 11:31 AMninjaimasta says:
lol Tool you just inadvertently linked your comment to Lost (the TV series) lol
Mar 25, 2008. 11:32 AMninjaimasta says:
sorta... lol
Aug 23, 2010. 11:32 AMthepelton says:
When I make small items that could end up in the mouth, such as a whistle, I make sure that I know what the wood is, and that it isn't a variety that could cause someone a rash from contact. In making whistles, I would avoid the entire genus of Dalbergia (Rosewood, Tulipwood, Cocobolo) for that reason. Tulip poplar (Liriodendron Tulipfera) is not related and would probably work quite well for the use. It was preferred by the pioneers for making wooden spoons because it had almost no chemicals that could impart a flavor to whatever it contacted.
Jun 8, 2010. 9:02 PMyoyology says:
Nice work!
Both my grandfathers were inveterate tinkerers, and would have loved Instructables. My mom's dad made me a willow whistle one summer, and your 'ible reminded me of that. User "shoemaker" shows you how to make one here.
I leave you with this thought:
I made a wooden whistle, but it wood'n whistle.
I made a steel whistle, but it steel wood'n whistle.
I made a tin whistle, and now I tin whistle!
Mar 15, 2010. 12:27 PMjoeyjo says:
Nice little project.  I do pay attention to wood toxicity because every so often a student has a weird reaction to some woods...nothing serious...which is why I refer to the toxicity chart.
Feb 24, 2010. 10:36 PMkmelon says:
cheers man mine works really well. if i say triple the scale will it give out a deeper sound like a trains whistle?
Nov 28, 2009. 8:09 PMKnyte7 says:
Thanks for the great instructable.  Clear and complete.  I've made whistles in the past, but with only limited success.  Using my lathe and these instructions should be a big upgrade.
Apr 3, 2009. 3:04 PMluke11 says:
Ok i've tried this several times but every time my whistle doesn't 'whistle'. No sound. Can you tell me what i might be doing wrong? Thanks
Apr 3, 2009. 3:38 PMSinAmos says:
Sweet.
Aug 8, 2008. 6:15 PMkaptaink_cg says:
How critical is the hole diameter? Does the diameter only vary the tone, or is there a point at which it will not work?
May 11, 2008. 6:37 PMmartymunch says:
I made a few of these this weekend. They are fairly easy to make once you get the right angles down. It was very tricky making the fipples until I got one to whistle. AWESOME!!! fav, and my two little kids love them!
May 15, 2008. 7:04 PMMadMechanicMike says:
i find that making the fipple last is the best method. i use a dowel and cut it a little longer than it should be then put it in and blow it. I then move the fipple as needed. also, i cut my window and lip halfway through the barrel at a little more than a 45 degree angle. another thing to try is to drill straight through the whole whistle stock and insert a dowel. you can tune the sound of the whistle by moving the dowel in and out.
May 19, 2008. 8:39 PMmartymunch says:
So I forgot to post this. Over the weekend I did try the slide whistle idea. It doesn't work so well as it is to hard to get an air tight seal and still be able to slide the dowel.
May 17, 2008. 11:42 AMmartymunch says:
i might try the slide whistle today. I'll get back to you on that. thanks for the info.
May 18, 2008. 3:48 PMpeguiono says:
thank you i made 2 whistles this weekend the both work great!! thank you
Apr 3, 2008. 1:01 PMMadMechanicMike says:
i made about 5 of these in wood shop but they are square. i made 2 double barrel ones, a triple barrel, and 2 single barrels. pm me if you want to see them.
Apr 27, 2008. 7:49 AMMadMechanicMike says:
here they are and then some extras. the bad looking ones are my first attempts. they all work. i just recently tried one on the lathe and it worked great.
Mar 26, 2008. 8:48 AMCharles IV says:
Blah you beat me to it. I was about to make this same Instructable.
Mar 24, 2008. 4:23 AMDIYmaster says:
Wow, this is amazing!!! Nice work!
Mar 23, 2008. 8:01 AMClayton H. says:
You can probly turn this into a ocarina if you make it a little bigger.
Mar 23, 2008. 6:47 AMLMO says:
This is now on my To-Do list. Great instructable.
Mar 17, 2008. 1:52 AMBig Bwana says:
Very nice, and simple to make a bunch of them, and thanks for the link to toxic woods...
Mar 15, 2008. 12:10 PMStrombergundy says:
Is that Zebrawood? I turned a bowl out of zebrawood once - it's not very easy to use on a lathe because it's such a hard wood. It splintered a lot and was very scary but eventually I got down to a bowl. Nice instructable by the way! I was going to make a spear that whistled but I didn't know how, I think this will help a ton.
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
