Make Your Own Wood Comb!
4,462
59
6
Posted
Introduction: Make Your Own Wood Comb!
In this video I will show you how to make your very own beard comb!
Wood combs are awesome because they help distribute your natural oils and do not create static, which leads to split ends and weird beard. You can make one with limited tools. I use a scroll saw in this video, but you could use a coping saw with a steady hand a little elbow grease and achieve the same result.
Step 1: Prepare Your Blank Wood.
Start with a piece of wood that is at least 1/4" thick. Depending on the type of wood i'm using sometime I will use stock up to 3/8" thick. Remember to orient the teeth parallel to the wood grain!
Step 2: Transfer Pattern and Drill Tooth Tops.
The next step is to draw your pattern onto the wood. I design my combs digitally and use my vinyl cutter to make a sticker for a template. You can freestyle your pattern, use carbon paper, or print and glue your pattern onto the wood.
After the pattern is applied, use a 1/16" drill bit to make small holes in the gap between the top of the teeth. This will make it easier to cut the teeth out and provide you with a nice round radius at the top.
Step 3: Time to Cut!
Cut them teeth!
Dremel Motosaw is an inexpensive way to start scroll sawing and it works very well. That's what I use and I love it. You could achieve the same cuts with a coping saw, however, it will require some serious elbow grease.
Step 4: Looking Good.
Now that you are finished cutting out the designs, remove your template (if you have one) and get ready to make some dust!
Step 5: Tapering the Comb.
Here I use a belt sander with 80 grit paper to taper the teeth of the comb. I like to leave about 1/8" at the tip of the teeth.
Step 6: Smoothing Out the Edges.
The dremel sanding drums make this step very easy, but you can achieve the same effect with round files and sandpaper.
I like to use the drums to remove any imperfections from the sawing process as well as beveling the sharp edges on the outside of the comb.
Step 7: Roughing Out the Teeth.
Use a sharp chisel to remove the sharp edges between the teeth, creating a rough cylindrical shape. This step doesn't have to be perfect. Any imperfections will sand out in the next step. Remember to remove small amounts at a time and don't take off too much!
Step 8: Sand, Sand, and Then Sand Some More.
Now here's the (fun) part: sanding the teeth and the edges of the comb. I use flexible 3M sandpaper that you can find at most any hardware store. I start with 100 grit and sand the teeth into a smooth cylindrical shape stepping down to 120 grit then 150 grit. Sand around the edges of the comb for a nice, smooth, round edge.
Step 9: File the Gaps Between the Teeth.
Filing a small bevel at the top of the teeth makes the comb glide nicely through hair without snagging.
Step 10: Applying the Finish.
A light finish is all you will really need to protect the comb. It will absorb your natural oils and keep the comb looking nice for a long time. I use this beeswax and orange oil finish. Its nice and easy to apply and looks and smells great after its dry.
Step 11: Buffing the Finish.
I like to buff the finish after it has dried to add a slight luster. You can use a buffing wheel or even a nice soft rag.
Step 12: Enjoy.
Feel the goodness. It's nice, right?
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
6 Comments
I watched your youtube video on this. When I clicked the dropbox link for the pattern. It says it can not find it. I was just letting you know and wondering if you are still letting people use the template.
I fixed it, thanks for the heads up!
https://drive.google.com/open?id=0B6kAT_xG4AmLOVo5OXZPVnJPQlk
Nicely done! I've actually been wanting to make my own beard comb for a while. This looks like a great approach.
Thanks! Its a piece of cake and you can really get creative with the designs.
I've never heard of anyone making a comb out of wood before. That turned out great! Thanks for sharing and welcome to the community!
Hey! thanks for the feedback! I appreciate you watching my video!
