3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Makebooth a D.I.Y. for a micbooth
Step 2Constructing the 1st wall
-Take two of the beams with the sizes 2,45m x 5cm x 2,5cm. I've chosen the 5cm wide beams because it will match the 5cm from the polystrene blocks perfectly.
-Since we're gonna build a frame of woodbeams that will surround the polystrene blocks we need 2 beams of 1m x 5cm x 2,5cm as well.
-Make sure the inside of the frame is exactly 1m wide meter so the polystrene blocks will fit inside.
-The 2,45m length is the hight of my room so the frame will fit standing up.
-screw the frame together.
-Now take the hardboardplate of 2,45m x 1,05m (the wide of the frame) and nail it to one side of the frame using some proper nails.
-Fill the inside of the frame with the polystrene blocks. Since the hight of the room is 2m45 we're not completely using all the polystrene, but save the leftovers! Make sure the are no spaces between the blocks. Fill them if you can.
-Take the second hardboardplate and cover the other side of the frame so you create a nice solid wall that will fit standing up in your room.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:themakeclass
