Introduction: Makedo Carp
Create a carp with the most simplest material found in your home. All you need is an empty tissue box and Makedo re-pins and re-clips available at mymakedo.com.
This instructable was designed by Tanaka Satoshi, Makedo's master maker in Japan.
Step 1: Find
Source an empty tissue box and cut down 1/4 of the way down of the four edges.
Step 2: Punch
Bring the top and bottom corners together and use the point end of the Makedo safe-saw to punch a hole through the card.
Step 3: Connect
Connect using a Makedo pin and clip. Repeat step 2 and 3 on the opposite side. This should create a rounded head for your carp.
Step 4: Score
Turn over the tissue box and use the point end of the Makedo safe-saw to lightly score two lines from the corner to the centre. Fold the score line as shown in the image.
Step 5: Cut
Turn the box over and cut a slit at the end of the tissue box hole. Fold in the flaps as shown in the image. Use the Makedo pin and clip to connect the bottom corner to hold the folds made in step 4 and 5.
Step 6: Build
Create a fin at the end of the box, made from the slit cut previously.
Step 7: Build
Turn over the box and using the Makedo safe-saw, saw flippers from beneath and fold them out.
Step 8: Share
Your Makedo carp is complete. Top it off with a tissue coming out from above as a fin. Share and upload your creation to mymakedo.com.
