3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own Lightning Globe!
Step 4Prep the stand
Prep the stand
To prep the stand (cheap plastic pot), cut out a hole in the top the size of the light bulb stem. You'll also need to cut a slot on one side to allow the high voltage wire to pass through.
Cut a small hole in the side of the pot about four inches off the ground. The high voltage wire will pass through here, so it must be high enough that it won't try to arc to ground.
Feed the wire through the side hole, then through the top and attach it to the bulb.
Now slide the bulb into the pot and it's done.
It's not pretty to look at, and it's not supposed to be. It's for use at night.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
96
Author:NK5
