MakerSpace Project
Published
Introduction: MakerSpace Project
Kinetic Rubber Band Car
Step 1: Materials
8 Gray End Connector
2 Yellow Rod
2 Blue Rod
1 Red Elbow Connector (the one in our model is gray)
Tape (of any kind)
4 Wheels that fit the kinetics
3 Rubber Bands
Step 2: Axle 1
Part 1: Tape the Rubber Bands together, then Tape to the Yellow Rod
Part 2: Slide 2 Wheels on and lock into place with 2 Gray End Connectors
Step 3: Axle 2
Step 1: Attach the Gray Elbow Connector to the middle of the Yellow Rod
Step 2: Slide a Wheel on either side then attach the Gray End Connector
Step 3: Keep space between the Wheel and the Gray End Connector and tape the inside of the Wheel to the Yellow Rod
Step 4: Axle Connectors
Step: 1 Remove all the Gray Connectors from the 1 and 2 Axel's
Step: 2 Apply 2 Gray End Connectors to the Blue Rod and slide the circle end to the Axel Rods
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    does it work? no.
