Remove these ads by
Signing UpStep 1: Tools and consumables
30-31gauge coated nicrome wire
kapton tape
soldder preferably high temp
1/4" OD copper tube
furnace cement
TOOLS
file
sciors
tooth pick
lighter
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Why not simply use a Vitreous Enamel power resistor such as this one
http://uk.farnell.com/vishay-sfernice/rwm04106r80jr15e1/resistor-ww-3w-5-6r8/dp/1109220
It is commonly used in the Reprap heater block design pioneered by Nophead.
Much cleaner and you don't need the cement, nichrome wire etc.
